WTB: Mounting Bracket for Bowman Cooler
Hello all:
Looking for a water outlet mounted bracket that fits the later Bowman oil. This is the one that sits behind the oil cooler with one end fastened to a stud and two bolt holes for attaching to the ears of the oil cooler.
Thanks for looking!
Scott
Given Name: Philip
Re: WTB: Mounting Bracket for Bowman Cooler
Post by PJGD »
Support Bracket_Bowman Cooler.pdf
Hi Scott,
Have just seen your posting for a Bowman cooler support bracket. I have one, but expect to use it on my car, however here is my drawing of it:
If you look at my engine rebuild write-up in the Gallery [bottom of page] here: pdf
Well, this is how cleaning out the loft works:
I need a bracket.
James loans me one to copy.
I think it must be easier to buy one.
You guys offer guidance on making one.
I find two in the bottom of a box of brake parts.
Merry Christmas!
Scott
Given Name: Philip
Post by PJGD »
Well, you can't beat that!
I will be interested to hear if they are both identical, particularly in the length between the mounting holes. . .
Yes, they are the same dimensions. So, I guess I should edit this to say:
For Sale, Bowman Oil Cooler Mount!
