Maybe some useful leads and translations
http://www.oldclassiccar.co.uk/freeads/ ... adford.htm
http://www.oldclassiccar.co.uk/freeads/ ... avelin.htm
http://www.oldclassiccar.co.uk/freeads/ ... upiter.htm
The ebay panel on the left also brings up Jowett related stuff.
Of course one of the classic problems when dealing with old car parts over international boundaries, is that of terminology. Despite several countries speaking more-or-less the same language (in this case English), many terms and phrases vary, so included below is a quick reference guide for anyone wishing to 'translate' UK motoring terms to their US equivalent(s), and vice versa!!
US -> UK translations:
1st gear => Bottom gear
Antenna => Aerial
Axleshaft => Halfshaft
Back-up => Reverse
Barrel => Choke
Barrel => Venturi
Car-top carrier => Roof rack
Coast => Freewheel
Connecting rod => Trackrod (steering)
Convertible => Drop-head coupe
Cotter pin => Split pin
Countershaft => Layshaft (gearbox)
Dome lamp => Interior light
Driveshaft => Propeller shaft
Energiser => Battery
Fender => Wing
Fender => Mudguard
Firewall => Bulkhead
Flashlight => Torch
Float bowl => Float chamber
Freeway => Motorway
Frozen => Seized
Gas pedal => Accelerator
Gas tank => Petrol tank
Gasoline => Petrol
Generator (AC) => Alternator
Generator (DC) => Dynamo
'Gone South' => 'Gone West'
'Gone West' => 'Gone South'
Ground => Earth (electrical)
Hard-top => Fast-back (coupe)
Hard-top => Coupe (Fast-back)
Header => Manifold (exhaust)
Heat riser => Hot spot
High => Top gear
Hood => Bonnet
Kerosene => Paraffin
Lash => Clearance
Lash => Free-play
Latch => Catch
Latches => Locks
License plate => Number plate
Liftgate => Tailgate
Lock (valve spring) => Split cotter
Lug nut => Wheel nut
Muffler => Silencer
Oil pan => Sump
Panel wagon => Van
Parking brake => Handbrake
Parking lights => Side lights
Pinging => Pinking
Piston pin => Gudgeon pin
Pitman arm => Drop-arm
Primary shoe => Leading shoe (brakes)
Prussian blue => Engineer's blue
Quarter window => Quarterlight
Recap => Retread
Recap => Remould
Ring gear => Crown wheel
Rocker panel => Sill
Rotor => Disc (brake)
Secondary shoe => Trailing shoe (brakes)
Sedan => Saloon
Sheet metal => Bodywork
Shift => Gearchange
Side marker lights => Side indicator lights
Snap-ring => Circlip
Soft top => Hood
Stabiliser or Sway => Anti-roll bar
Station wagon => Estate car
Tang, lock => Tab washer
Throw-out bearing => Thrust bearing
Tie-rod => Trackrod (steering)
Tire => Tyre
Torch => Acetylene cutting torch
Transmission => Gearbox
trouble-shooting => Fault finding
trouble-shooting => Faulting
trouble-shooting => Diagnosis
Trunk => Boot
Turn signal => Indicator
Turnpike => Motorway
Valve cover => Rocker cover
Valve lifter => Cam follower
Valve lifter => Tappet
Vise => Vice
Whole drive line => Transmission
Windshield => Windscreen
Wrench => Spanner
Wrist pin => Gudgeon pin
UK -> US translations:
Accelerator => Gas pedal
Acetylene Cutting torch => Torch
Aerial => Antenna
Alternator => Generator (AC)
Anti-roll bar => Stabiliser or Sway bar
Battery => Energiser
Bodywork => Sheet metal
Bonnet => Hood
Boot => Trunk
Bottom gear => 1st gear
Bulkhead => Firewall
Cam follower => Valve lifter
Catch => Latch
Choke => Barrel
Circlip => Snap-ring
Clearance => Lash
Coupe (Fast-back) => Hard-top
Crown wheel => Ring gear
Diagnosis => trouble-shooting
Disc (brake) => Rotor
Drop-arm => Pitman arm
Drop-head coupe => Convertible
Dynamo => Generator (DC)
Earth (electrical) => Ground
Engineer's blue => Prussian blue
Estate car => Station wagon
Fast-back (coupe) => Hard-top
Fault finding => trouble-shooting
Faulting => trouble-shooting
Float chamber => Float bowl
Free-play => Lash
Freewheel => Coast
Gearbox => Transmission
Gearchange => Shift
Gudgeon pin => Piston pin
Gudgeon pin => Wrist pin
Halfshaft => Axleshaft
Handbrake => Parking brake
Hood => Soft top
Hot spot => Heat riser
Indicator => Turn signal
Interior light => Dome lamp
Layshaft (gearbox) => Countershaft
Leading shoe (brake) => Primary shoe
Locks => Latches
Manifold (exhaust) => Header
Motorway => Freeway
Motorway => Turnpike
Mudguard => Fender
Number plate => License plate
Paraffin => Kerosene
Petrol => Gasoline
Petrol tank => Gas tank
Pinking => Pinging
Propeller shaft => Driveshaft
Quarterlight => Quarter window
Remould => Recap
Retread => Recap
Reverse => Back-up
Rocker cover => Valve cover
Roof rack => Car-top carrier
Saloon => Sedan
Seized => Frozen
Side indicator light => Side marker lights
Side lights => Parking lights
Silencer => Muffler
Sill => Rocker panel
Spanner => Wrench
Split cotter => Lock (valve spring)
Split pin => Cotter pin
Sump => Oil pan
Tab washer => Tang, lock
Tailgate => Liftgate
Tappet => Valve lifter
Thrust bearing => Throw-out bearing
Top gear => High
Torch => Flashlight
Trackrod (steering) => Tie-rod
Trackrod (steering) => Connecting rod
Trailing shoe (brake) => Secondary shoe
Transmission => Whole drive line
Tyre => Tire
Van => Panel wagon
Venturi or Choke => Barrel
Vice => Vise
Wheel nut => Lug nut
Windscreen => Windshield
Wing => Fender
Wanted in Montevideo, Uruguay
need a dashboard and others parts
(Years applic: 1952 ) 059899687079
Read more at http://www.oldclassiccar.co.uk/freeads/ ... lU0z0jX.99
