Bradford Gugdeon pins?
I need a couple...
It is my understanfing that these may also fit thu mat need a little machining/ shortening
Specs For the Bradford (2 cylinder engine) 3/4" dia (19.05mm) x 2.75" long (69.85)
INDIAN 19.04 (3/4") x 73.4mm
Royal Enfield 500 Bullet 3/4" x bore 84mm Bradford bore 79.4mm
Ford CTPK-6 19.05 72.7
2N-6108-4RS 19.05 72.6
HARLEY PISTON FLAT HEAD 20.1 71.1
1200cc 20.1 71.1
1340cc 3 1/2" bore 20.1 71
Steps.
