I have been reading through the posts on rebuilding the Javelin/Jupiter rear brakes and see that Castrol PH grease is recommended for lubricating the handbrake mechanism and brake shoe abutments.
I have had a quick search for PH grease and it seems to have been replaced by Castrol CL grease. Has anyone any experience of using Castrol CL?
Replacement for Castrol PH grease
John Dolphin
John Dolphin
E3SA 887
E3SA 887
Re: Replacement for Castrol PH grease
I use it. For such applications you need something that is water repellant.
Drummond Black
- Given Name: Drummond
Jonh, I also use it for areas that can come into contact with water. I use it on the Jav/Jup handbreak rollers, water pump etc.
Drummond
Drummond
John Dolphin
Thanks for the replies chaps, I have been down to Halfords and picked a tub up.
John Dolphin
E3SA 887
E3SA 887
