jowett javelin parts on e-bay
p.p.
Given Name: peter
Post by p.p. »
there a engine, gearbox and and on e-bay
no. 220737375641 gearbox
no. 220737376862 engine block
is it wort to get it as spare part ??????
and all the other part's listed ?????
peter
Re: jowett javelin parts on e-bay
Obviously depends on condition. This looks a lot cleaner than most and has been sympathetically dismantled. A cracked block with over worn crank and camshaft is not worth a lot. A useable block with regrindable crank and reprofileable cam is perhaps worth £500.
Same with box, a worn box is worth very little; but if it all still works then perhaps £100. Ask seller if how waggly the gearbox input shaft is, or if he knows the state of the crank bearings or cam lobes
A spare rebuilt box and engine is really worth it as you can spend time on rebuild if anything goes wrong after swapping in the replacement.
p.p.
Given Name: peter
Post by p.p. »
i just got the hole lot ...... :wink: :!:
he will get it in a big box ... :)
i just have to get it to switzerland ??!!?? or i will get it fixet and rebuild the engine in england.....need a member to look the "bargain" in manchester.... hopefully ther is same helping member.
peter
Users browsing this forum: Google [Bot] and 24 guests
