What is the significance of a Matching number Jowett?
By this I mean a Jowett, that has orginal engine block, gearbox, diff..serial numbers all match...basically orginal steel body parts, hand books etc.
The definition I have found does vary greatly between countries, car clubs, and manufacture (make) of cars
Are there any giudelines for Jowett.
What Difference does this place on market and insurance values.
EG
I have a 'matching' numbers 69 Camaro.
All body parts panels stamped with factory serial numbers are orginal, block, trans, diff..other parts that wear out are replaced with correct parts with correct part #s..and if this is not the case the orginals are stored safely...orginal warrante papers, handbooks, tools etc etc
Insurance valuation is close to market....non matching numbers for the same car means around the $NZ 45,000 ...with matching numbers $NZ 65,000
I have a Bradford that the body, chassis..well just about everything is beyond resto...One of our far more knowledgable club members was digging thru it and found it does have matching body tag and engine tag...
Im unsure what direction I should take.
Should I resto another project and use these tags? doesnt really seem honest thu
So I need to know what the general international jowett comunity thinks, opinions or if there is a policy or definition????
Matching number Jowetts
Non-matching numbers may effect value if the car has some history, particularly competitive. Also body panels may show the car has had a bump. Jowetts were not very consistent in production so not too much store should be placed on them. However, matching halves of crankcases is a good idea, although I have put different ones together with no ill effects.
