I seem to have found a possible source for replacement wheels for the Jupiter, Javelin, and possibly others.
I remembered a discussion with Keith when we were sorting through dozens of wheels for the SC project, where he mentioned there were old Saab wheels that fitted, and that to get a wheel balanced was a bit of a job due to the bolt spacing but that there were Saab wheels that used the same bolt spacing etc.
So, a bit of a hunt around has turned up these, available from a good manufacturer of alloy wheels, Compomotive:
http://www.comp.co.uk/wheels/wheels.asp?range=HSP_0048
They look to be correct bolt spacing, I am investigating whether these actually do fit, but could be a good alternative to 60 year old steel wheels that when we were investigating had cracks showing on some wheels and which will eventually become in shorter supply.
From the discussions the Saab guys seem to be having about these wheels online, they were previously very very expensive, and even secondhand steel wheels for their cars have got to similar price if not higher.
I contacted them and they don't know if they will fit a Jowett, the wheels are 5" wide, 15" rim. I think this will fit using the same tyres we do on the steels. Can someone confirm?
They aren't pocket change though, £850 for 5 without tyres, and lead time will be approx 4 weeks. Apparently Kuhmo do a tyre which is readily available and fits these wheels, but I don't know what the fit would be like under the arch with those tyres fitted.
All this said, I've never seen alloy wheels for a Jowett hub before, so one to be aware of if anyone is looking to "pimp their ride". They should look pretty cool, kind of like a Minilite wheel which is a classic look, and the centre of the wheel should be big enough to hide the drum brakes behind it and also possibly help with keeping the drums cool.
I'll be doing some more research and will report back, if anyone has any specific questions or knows whether this kind of wheel has a chance of fitting, just shout.
