Ring Gaps
kemp1942
- Your interest in the forum: Lifelong interest in Jowetts
- Given Name: Ian
Ring Gaps
Anyone know what ring gaps should be for 7 and/or 8 HP ? On my good piston (from the recon engine that started to sieze just before the Rally, damaging a piston and destroying the rings) the gap is 22 thou - this is an '8' std piston. I have gotten some replacement rings which have a 13 thou gap - wondering if I can leave them or should I gap them at 22 thou ( In the back of my mind is 4 thou per 1" of barrell bore which would equate to about 12 thou ?????????
A Bulldog is for life
Peter Holden
Re: Ring Gaps
Ian
Does the attached help[img]
Re: Ring Gaps
Hi Peter,
You will see that I edited the post by resizing your pic so that it could be read. however a rescan or resize from your end might be better as some definition has been lost. Aim for a file size of about 100 to 150 k. Since it is black and white a GIF file may be better than jpg.
Seems like Ian is going for a race engine, semi air cooled.
Leo Bolter
Re: Ring Gaps
. . . . or download this (340 kb):
http://60.234.149.204/Leo/Forum_Files/J ... ions_1.doc
NOTE: The original of this document was included inside a carton containing an unused set of “Repco” brand (Australasian company) semi-finished Jowett Javelin pistons. (This .doc is normally available on my section of the Gallery, but it is not at the moment, "due to maintenance being done").
The ring gap recommendations are found at the top of page 2. I quote:
Recommended Ring Gaps.
[b][u]Air Cooled Racing Engines: -[/u][/b] Not less than 0.005"|[b][u]All other engines: -[/u][/b] not less than 0.003" I hope this helps . . .
Leo
Leo
kemp1942
- Given Name: Ian
Re: Ring Gaps
Thanks all - since it seems they should be at least 003" x 3in = 009", looks like I can leave them at 013" - can't add any metal back on !. I'll replace the pair on the 'good' piston which are circa 022"
Re: Ring Gaps
I don't want to add confusion but in a 1935 'Practical Motorist' it states the gap should be 0.002in between the slotted ends of the rings when positioned in the bore - firstly, that is considerably less than the 3thou per inch formula; secondly, what do they mean by 'slotted ends'?
