javelin ignition
tiffy
javelin ignition
Post by tiffy »
Ihave replaced my distributor with an electronic type.The inside doesnt have anything other than rotor arm rotor and what iassume is the module.Now can anyone guide me through setting it up please?First there are two wires from the dizzy one red and one black,where do these go to?How do you do the static timing initially,is it the same method as conventional dizzies?What type of coil will i need?what type of spark plugs?Is there anything else i need to think about?Thanks very much for any advice andhappy motoring. :?:
