Clutch material
Cyclecars
Your interest in the forum: Just purchased a Jowett Short Two. Here to learn about the car.
Re: Clutch material
Post by Cyclecars »
K,
This is VERY helpful. I suspect I have tainted the clutch with gear oil. I used the proper heavy lube, but I still do not know how much to put in. I used a dip stick, but not sure where to measure from (the very deepest part or the upper part?). I think I now know; less is probably appropriate. I
I will try some fullers earth and adjust as recommended. I hope it gets it good enough for a while I need to leave the car alone and drive it until end of 2025 when I can pull it all out and rewind some rope on the clutch. I see no way of removing the clutch without pulling the engine. I have to hold off doing so on that until at least a year from now. Long story... But I can't do it until next winter.
So this was extremely helpful information. THANK YOU!
- Keith :D
1922 Amilcar CC
1924 Jowett
1925 Trojan Utility
1926 Humber 9/20
1952 Bradford special
Given Name: Ken
Re: Clutch material
Post by k. rogers »
The correct level of oil in the gearbox is 2 inches on a dipstick. I made one out of a thin but firm piece of wire, painted the bottom two inches in a matt colour. You can carefully poke it down the breather tube which is visible on the gearbox top cover, making sure it actually touches the bottom. It is difficult to assess as the wire invariably touches a cog or something on its way down, but try several times and you'll hopefully see the level.
Cyclecars
Re: Clutch material
Post by Cyclecars »
Perfect! Thanks again. I use a bicycle spoke. I just needed to know which level of the casing to stop. Using the vent hole makes sense. That way the location to go straight down is well defined. I was using the uncapped filler hole and it hits a shallower area. I filled to two inches form there. That has to be too much. The car is settled in for the winter now. So this will be an early spring session to get it back on the road.
Cheers from the early season deep snow here in Michigan!
- Keith
1922 Amilcar CC
1924 Jowett
1925 Trojan Utility
1926 Humber 9/20
Given Name: Ken
Re: Clutch material
Post by k. rogers »
Good luck Keith and keep us updated!
