My new Speedograph Cable has broken
All was working OK until my speedo stopped working, whilst taking part in a road run today. I checked that the cable was turning, which it was after I UN coupled it from the speedo.
I took my Speedo apart and noticed that there is, a silver, free spinning circle which when you spin it, moves the needle. That was OK. But, there is also another device in-between that and the outlet for the cable, which wouldn't turn. It was seized.
I very carefully sprayed some W D40 and tried turning the instrument using a screw driver. I was able, after a number if turns to spin this "Yellow" looking object by hand and, with my old cable attached I could turn it and see the needle moving.
I then put all this back together and took the car for a road test, only to find that the cable had stopped turning. So back home out with the jack and look underneath. I unscrewed the cable from the gear box and saw what had happened. The wires had unwound themselves.
This must have taken some clout, and I can not believe I had a faulty cable. When I installed this cable my Dad and I both made sure, that there weren't any kinks or bends in the cable. The only thing that I did do, was too tighten the screw at the gear box end with grips. Apparently so I have read, they should all be screwed by hand!
So I have two questions for you.
1 Could a seized speedo cause the cable to brake at the gear box?
2 Or could over tightening, of the locking screw on the gear box, with grips, cause the cable to brake?
