All in exchange for a bit of your time and expertise
You may have seen from this thread (http://jowett.net/forum/viewtopic.php?t ... sc&start=0) that we are rebuilding my SC. We're doing pretty well, and he's definitely beginning to look more like a Jupiter, but in order to have him on the road in time for Wakefield, we're going to need a bit more help.
I'm sure Clements senior will be along shortly with details of the main things that need doing, but in no particular order we still need to:
- finish making the boot pan
- fix the boot lock
- install gearbox and engine
- sort out master cylinder, finish off a couple of brake pipes, test the brakes
- fix the handbrake
- install wiring loom, hook up to all relevant electrics...
Oh, and sand, fill and paint all of the bodywork however many times it takes to finish them (I've done the first sanding, now we just need to beat, fill, sand, paint, sand, paint, etc... ).
What I'm proposing is this:
We will provide beer, pizza / other takeaway (and beds if necessary) together with entertaining banter and embarassing stories about Clements senior in return for your time and Jowett expertise.
Dates that I suggest are:
March 6/7
March 20/21
April 3/4
May 1/2/3 (bank holiday weekend)
And if we're not on the MOT stretch by then we're a bit stuffed anyway, so I won't suggest any more dates
If you are willing and able to make any of the above, please post below so we can keep track of who's planning on turning up. If you're likely to need a bed for the night, please also say so and we'll make sure that's sorted out.
It goes without saying that we'd be incredibly grateful for any help, and it'd be wonderful to be able to drive the SC to Wakefield.
Thanks in advance,
Amy (aka Clements Junior).
