10 hp parts.
10 hp parts.
Perhaps our members in France or any 10hp owners would like to respond to Gilles.
BONJOUR
IM FRANÇAIS ET JE RECHERCHE DE PIECES POUR MOTEUR A 4 CYLINDRES SOUPAPE laterale.
Avez-vous des pièces différentes pour ce moteur?
OU PUIS-je trouver des pièces pour ce moteur?
BEST REGARDS
GILLES
g.d.t@orange.fr
BONJOUR
BEST REGARDS
GILLES
g.d.t@orange.fr
Alastair Gregg
D7 CB 6079 CVG 166
For our Non French speakers
Google and Babel fish both do translations of various languages. I am putting the, very literal, translation of what Gilles and Forumadmin are talking about up for you. Should you wish to respond the translation pages are :
http://uk.babelfish.yahoo.com/translate_txt
http://translate.google.com/#
However here is what Gille said to Keith:-
HELLO IM FRENCH AND I SEARCH FOR PARTS FOR ENGINE have 4 CYLINDERS SIDE VALVE. Do you have different parts for this engine? OR can I find parts for this engine? BEST GLANCES GILLES
and what Keith said to Gilles:-
HELLO S' you like it to see l' posting on JowettTalk. You will need d' to be member of the club d' to buy spare parts of the Club of cars Jowett spare parts in stock. However, certain members of May being in d' measurement; to help.
Compliments of the Season,
Alastair Gregg
Alastair Gregg
Alastair Gregg
D7 CB 6079 CVG 166
New member and language
I have asked a near native French (English)speaker to contact Gilles and hope he will.
Alastair Gregg
Alastair Gregg
- Given Name: Paul
Alastair Gregg
D7 CB 6079 CVG 166
Contact has been offered
Further to previous post, a JCC member who speaks French has e-mailed Gilles, and hopes to help him.
So am not sure if your suffering will be relieved yet Paul
Alastair Gregg
Alastair Gregg
vicboddy
- Your interest in the forum: Information. I have spares which have helped club members in the past. Obtaining info on equivalent parts, eg where to find shock absorbers for a Jupiter
- Given Name: vic
Hello Folks
I have been able to talk to Gilles. He does not have a 10hp car....he has a BRISTOL tractor with a 4 cylinder side valve flat four engine, which he believes (and I do not know) is the same engine as fitted in the 10hp car.
The tractor engine is missing the valves, distributer, timing chain, flywheel, starter motor (if there was one, he has a crankhandle).
Can anybody elucidate? Personally I have heard of twin cylinder Bristol tractors, not 4 cylinder, but it is not an area I know much about. Who in the club can I contact to try to help Gilles? If such a thing is available, he would be happy to buy a complete engine, rather than just the parts.
Regards Vic
Regards Vic
RGDS
- Given Name: Paul
Hi Vic, there are a fair number of Bristols with 4 cylinder Jowett engines. I suspect that they were fitted with a mag rather than a distributor and I wonder if that is where the initial problem lay as it would have been driven from the timing case much like the pre-war dynamo. If it is the same as the 2 cylinder stationary engine, it was probably a Wico mag.
There is an enthusiastic Bristol tractor club - they advertise regularly on British Ebay.
JCS probably has valves, STILL has cylinders and can probably supply ot source a timing chain. My guess is that the Mag could be a challenge, but I reckon that Tractor folk may be more helpful than we can be!!
Alastair Gregg
D7 CB 6079 CVG 166
Bristol Tractor
Alastair Gregg
Alastair Gregg
gilles83
Hello an tahnks a lot for you information
the engine number is J91401
It S 4 cylinders lateral valve
i try to post a photo for you see the modele of the engine
I search technical, parts book to see the missing parts
i m sure i'm missing flywheel, carburator, valve, ignition( magneto) and another parts...
i try to post photo but i can't...
have you have an idea??
THANKS A LOT for you informations
best regards
GILLLES
best regards
GILLLES
gilles83
bonjour
Je crois que Je leur ai envoyé une photo avec succed! Parce que j'essaie Une semaine pendentif!
alors Pouvez vous de voir ce que le moteur.
Frew pièces manquantes sont: Le whell Mouche, soupapes, allumage (Magneto) du carburateur
Qu'est-ce que quelqu'un connais le modèle de carburateur, magnéto électrique équipée de ce moteur?
Le carburateur est-elle la même que 2 cylindres?
BEST REGARDS
GILLES
BEST REGARDS
GILLES
Alastair Gregg
D7 CB 6079 CVG 166
A Translation
A Translation:-
hello I believe that I sent a photograph with succed to them! Because j' test One week pendentive! then Can you see what the engine. Frew missing parts are: The whell Fly, valves, lighting (Magneto) of the carburettor Qu' quelqu' do one know the model of carburettor, electric magneto been driven by this engine? Is the carburettor the same one as 2 cylinders?
Alastair Gregg
Alastair Gregg
Bryan Walker
- Given Name: Bryan
