Size gentlemen please!
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Given Name: Alastair
Post by Alastair Gregg »
What size is the nut that holds the pully on the end of the crank on a Jav/Jup please. I have got back a rebuilt engine and best practice decree's that every few months you turn the engine to save the bearings. I tried with the starting handle but have insufficient purchase on a new (tight) engine.
Compliments of the Season,
Alastair Gregg
rob needs
Post by rob needs »
Is that with the plugs still in?
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
With The Plugs in
Yes it is I would expect it to be stiff but not impossible.
Alastair Gregg
paul wilks
Post by paul wilks »
Hi Alastair.
I have a spare Javelin engine (rebuilt by Roy Braddock many years ago) which I turn over every so often using a large 3/4" Whitworth ring spanner. Although spark plugs are inserted (and Roy insisted they be kept in place in the engine whilst out of use) the engine does turn over showing a good compression but not so difficult that I need to use a huge amount of force.
Hope this helps.
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Size Gentlemen Please
Thanks Paul,
My Socket /spanner set does not go to that size, but very shortly it will. Thanks for your help.
Alastair Gregg
Be careful I once broke the bolt. Sometimes the bearings are such a good fit that they suffer from stiction. Once moving, the engine turns; but very difficult to initiate. I have also relaxed the crankcase tie bolts slightly to overcome what might be an overtight engine. Of course that may indicate poor alignment of the main bearing housings or dirt under the shell or poor tolerance on grinding. Anyway it is a way of telling which bearing is causing the problem.
Given Name: ted
Post by TedAllen »
Further to above, I once broke the bolt trying to turn over an engine I had bought. I thought I was in trouble but found the remains of the thread came out quite easily just using a small screwdriver to push the shaft round by the rough end of the break.
I don't think the threaded shaft actually bottoms in the crankshaft but relies on the inner face of the starter dog to tighten against the pulley and end of the crank.
Ted
