https://goodson.com/products/crankshaft ... dius-gauge
I am in disbelief that UK crankshaft shops don't have a gauge.
Kings Langley garage meet
Re: Kings Langley garage meet
The places I tried were engine builders, not specialist regrinders. The one used by Classic Autos is 50 miles away.
The crank has been measured by Apsley Transmissions and confirms the 2.238 measurement I got except the rear main did have half a thou thinning which I will confirm tomorrow.
I will also measure the journal radius using the two methods.
Harry and I took the engine out of Amy's Jup and replaced it with the engine out of the Leopold Jup that I have re commissioned.
21 thou method valve timing
A direct link to the 21 thou method of setting valve timing viewtopic.php?p=46666#p46666
