• 1 head Gasket (E)
• Solder for head studs (E)
• Instant gasket
• Inner and outer valve spring (N), never needed one!! But take a valve spring cap.
• Valve stem cones (N) but make sure the ones you have on are not worn!
• Inlet and exhaust valve (P) unless the valve seats are bad. If you drop a valve it is going to do more damage than you can repair.
• Pushrod (E) particularly if you are bombing down a motorway
• Fan belt (P) but I have never needed one
• Con rod bearings (N) (Unless you intend doing 10000 miles) more likely is the rear main
• Con Rod tab washers (N) Take Loctite thread lock and use everywhere when assembling. Also do a spanner (nut) check before leaving.
• Accelerator cable (P) but plumb it in.
• Oil filter seal (N) but filter housing seal *3 (E)
• I would take oil seals for front and rear wheels and possibly front wheel bearings (unless you have used Addmax B3 grease).
• 4x Water transfer washers (E) Do not fit with gasket sealer!
• Radiator hoses (P) but fit new ones first.
• Oil cooler bypass pipe.
• 18swg wire (E) plus some insulated wire and tape.
• Petrol pump diaphragm and gasket (N) Take a complete pump either mechanical or electrical and a length of petrol pipe.(E)
• Gearbox plunger and rocker arm.(N) but a pair of selector forks.
• Fuses (E)
• Bulbs all (E)
• Condenser, contact points (P) but better is a complete distributor with leads and ignition coil, tested and marked for immediate insertion. Take timing light as well. (E)
• If you are doing any night driving a dynamo or alternator advisable.
• The list had a total lack of brake parts!!!
• 3 types of brake springs(e)
• Master cylinder and one each of all brake cylinder kits. Check you brake shoes before you go!!
• Selection of springs, clutch, accelerator (fit a second anyway), brake return.(E)
• Selection of nuts and bolts, inc wheel nuts.
• Wheel Inner tube.(E)
• Flexi Brake pipe front and rear (P)
• Carb float and needle(E)
• Spare car keys (E)
• Hub puller (p) heavy but useful.
• Multi-meter.(E)
Travelling spares suggestion from old JowettTalk
- Given Name: Paul
It is interesting what people consider priorities for travelling spares. I would not carry a puncture kit as first of all I have a spare wheel and secondly would not attempt to mend a puncture anyway. Perhaps I might on a long distance rally when you might be miles from a garage and had suffered a second puncture in quick succession! Anyway when was the last time you had a puncture?
As regards fitting all that lot in a Jup, yes, I do, and many people who have ill prepared for a journey have benefitted from them. After all a mobile phone and the AA or RAC could not help; except to tow you home. I wish they would learn to carry their own. The kit goes in the spare battery compartment and spare wheel tray where there is also 5 litres of oil and petrol and 2 litres of water. The boot is always free for luggage.
Some priorities do change depending on the event, time of year and any recent changes or unproven components. Clearly, if doing a mountainous event, brake spares, including shoes, are taken. Hugo managed to wear out a set of shoes in 3 days on the Tulip.
- Given Name: Michael
Touring Spares
G'dday,
Noted Pat Lockyear's mishap with the core plug episode.
Usually failure here is due to corrosion of the cylinder head casting where the welch plugs seat. Have several times enlarged counter bor to next size welch plug. Also, always use new brass welch plugs with suitable sealant.
The brass plugs seem to last well.
Keep at it!
Mike Allfrey - E0 SA 42R
Keep at it!
