Many years ago I saw a frame that was put on a trolley jack to remove & replace Javelin engines.
Does anyone have a pattern for that?
Javelin engine trolley
AlecGatherer
- Your interest in the forum: Newish member with birth year Javelin de luxe.
- Given Name: Alec
Re: Javelin engine trolley
If it is of any help, I used to use a modified skateboard.
I think that skateboards are rarer that Javelins these days!
DAVID,
I will post a pic tomorrow. It is a spigot ( shaft ) that fits into the trolley jack hole with the cruciform pad ( that normally supports what you are lifting ) removed.
This pad is replaced by a plate with two supports, a concave one that supports the flywheel ( with the clutch cover removed) and a flat one that supports the sump.
There may well already be a picture on here or in the archive.
Sure enough using the search server found this. download/file.php?id=7842
Not the same as mine.
Or this doing a J T search
viewtopic.php?p=30630#p30630
