Wanted: Bradford Handbrake Pawl
Jeremy
- Your interest in the forum: I now have a CB Bradford kit of parts - one special coming up!
- Given Name: Jeremy
Hi, I am after a Bradford handbrake pawl as mine is worn to uselessness - I have the lever and the ratchet but the pawl is no good. They were made from really hard material so making a new one is outside the scope of my garage equipment. If anyone has one or a complete working handbrake I would be most grateful.
Re: Wanted: Bradford Handbrake Pawl
Jowett Car Spares?
The hardness can be induced into steel through hardening. https://en.wikipedia.org/wiki/Hardened_steel
StevenGray
- Given Name: Steven
I have some NOS all I need to do is find them.
will have a look tommorow (Sat)
I am pretty sure that they are nothing more exotic than case hardened mild steel.
Steven
Steven
Bradford Owner since 1971
StevenGray
Jeremy
Have found them. will send you an email
Steven
Steven
Jeremy
Many thanks - hopefully problem solved.
Keith - the old one seems very hard indeed - I thought of JCS but no stock, and I thought of building it up with weld but not sure about the integrity of that. Hence the ask on here.
I welded up a Jupiter one and ground it to shape.
