Evening all.
I would be very grateful for an advice on fitting the above (hopefully the image has attached?)
I had hoped that it would simply involve swapping the pulley over but as you can hopefully see the shafts are of different sizes!
Any thoughts?
BW
Harry
Dynamo to Dynalternator?
harrynaerger
- Your interest in the forum: I own a Jowett Jupiter which has been converted for historic racing.
- Given Name: Harry
Re: Dynamo to Dynalternator?
Harry - Let me see what size the one I have in the workshop is / brand etc & take some pics - back later with some info - Chris
harrynaerger
- Given Name: Harry
Hi Chris
Very many thanks for getting back to me. I have been in touch with the manufacturers. The unit we were sent had a 15mm hub but we need a 17mm hub which they also stock so I will arrange to get them changed.
BW Harry
BW Harry
Yes Harry, I had no problem with the four that I have fitted. Perhaps you could post on here the supplier and part number that you used.
