Combined front side and flasher LEDs
Given Name: Roger
Post by 114 »
We've successfully used Classic Car LEDS supplied dual 'bulbs' to neatly introduce flashers to the front without making new holes or 'hanging stuff on' Very cleverly these 'bulbs' switch off their white LED's ' when the amber ones are selected on (ie when indicators are used with sidelights on). Erratic flasher LEDs and flickering white LEDs,But only engine running, were resolved by fitting an inline suppressor into the coil to distributor HT lead as suggested by CCLEDS. Apparently the (common) issue is RF interference from the ignition interfering with the solid state flasher unit required to operate the LEDs.
Re: Combined front side and flasher LEDs
This sounds like a good idea, can you please post picture or product code, so I can find some.
Given Name: Roger
Post by 114 »
Hi David
Try this link. Obviously you'll need a suitable flasher unit to match
Roger
https://www.classiccarleds.co.uk/collec ... ed-led-380
