Can anyone help me find the vintage correct Heater parts for E2SAL813. It was an option that 813 did not take, and I would like to install the heater but dont knoe=w what I need. Water pump valve, plumbing to firewall, interior hardware. I could use diagrams and pictures to piece together what I need. Any help appreciated.
Thank you.
Jupiter Heater
rickjowett
- Your interest in the forum: My great great grandfathers cousins were William and Benjamin Jowett, the founders of Jowett Cars Ltd!
1952 Jowett Jupiter E2SAL813
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4 - Given Name: Rick
Re: Jupiter Heater
Rick,
Have a search around the rebuilds of the SC and the SA. There should be pictures of what you need.
Try searching on jowett.net here . Also search the parts book
The water pump has a brass valve on it so I presume your pump has a plug in it. Plenty available in UK from JCS but maybe Scott has one.
The radiator has a half inch hose take off in the bottom of the radiator. The two pipes go through the bulkhead. The heater is held on by a large bracket bent from 2mm plate. The heater type is listed in the Technical Notes but a new or reconditioned one is very expensive. So much so I fitted one from a mini to my SA.
There are many discussions on JT about the heater!
search.php?st=0&sk=t&sd=d&sr=posts&keyw ... r&start=15
viewtopic.php?f=28&t=1461&p=42017&hilit=heater#p42017
download/file.php?id=10292&mode=view
viewtopic.php?f=163&t=2722&p=16011&hilit=heater#p16011
https://www.holden.co.uk/c/electrical/h ... ar_heaters
rickjowett
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
Re: Jupiter Heater
Thank you, I will enjoy reading through the links this morning.
