Petrol Pump Wanted.
Petrol Pump Wanted.
The Weasel has a glass bowl type AC fuel pump(Not the early pre war type.) ideally I would like to put this back to the proper late type mushroom top Pre war one. These are not the same as the Bradford one, as the fittings on a Bradford one are bigger. If anyone has one I would be interested in acquiring one.
BarryCambs
- Given Name: Barry
Re: Petrol Pump Wanted.
Hi Alan. I have the pump I took off my 1934 engine and replaced with a blanking plate as it seemed a bit of an over complication, given the tank on the Long Two is above the engine. You are welcome to it if it's the right one. Do you have a picture of the one you need? I also have the pump from the 1932 engine and that is the glass bowl type
Barry
Barry
Alan (and Barry),
If Barry's offer doesn't work out, I'll have a 'look-see' at my spares.
P.S. Lovely photo of you, Freddie and the car in the August J'tteer.
BarryCambs
- Given Name: Barry
Hi Tony
There was a cycle race going on when we were coming back and a photographer had set up with a sign advertising their website. I told Frederick to wave as we sailed past and when I looked in the evening, the photo was there!
I haven't forgotten about your kind offer to look for the steering arms. I have the measurements from Daniel's car now, but we were away on holiday and now off for 2 weeks from Saturday, so I was waiting until things got back to normal to sort it out. I've also had the offer of a seat from one of your fellow NW Sections members!
Barry
Barry
Thanks Barry & Tony.
I have just pm'd you Barry.
BarryCambs
- Given Name: Barry
I've just dug the pump out and it actually looks a bit more like the mushroom top one in you picture than I remember. I've no idea if it's the one that left the factory in 34 though, as it looks a bit modern to me?? You might have to turn the top 180 degrees to match your pipes and hopefully you can do that without damaging the diaphragm, as it does actually seem to work! I might have run the car with it on before I decided to go with good old fashioned gravity
Barry,
That looks like the one, are the pipes attached with their nuts?
Thanks for digging it out.
Hopefully should put the spring back in the step of the weasel.
The earlier ones were I think a diaphragm next to a glass bowl.
Alan
Alan
BarryCambs
- Given Name: Barry
Yes, they're screw connections, just someone left a stub of the copper pipe to connect flexible to. The pump off the 1932 ex boat engine certainly has the glass bowl set up. It's on its way to you
Hi Alan
See above as I can't cancel this one.
Hi Alan,
Don't forget to use PTFE plumber's tape on the connections, and Mazak is rather brittle.
If you remove the 'mushroom' it needs to be air-tight on replacement.
Perhaps use a smear of Hylomar on the gasket.
The central screw through the cap goes into the casting.
Use a new fibre washer between the mushroom top and the screw head, and go easy on tightening.
Barry: -
I was told by a good authority (Michael K-O) that gravity feed is fine EXCEPT when going up a steep hill on less than half a tank.
I found this to be true on my car's first outing. See the video on YouTube, "Jowett testing" will find it!
Enjoy!
Enjoy!
