Wiring question
ajg1722
Your interest in the forum: Current restoration projects: Bradford CC Truck, 1939 Tatra 57b.
Also have 1953 Ariel Square Four, 1958 Velocette Venom, 195? Panther M100, 1963 Standard 7cwt Van, 1963 Standard 7cwt Pickup, 1976 MZ TS250/1, 1984 MZ ETZ250, 2001 Toyota Hilux, plus a couple of CZ 175 bikes, all variously running or awaiting restoration.
Given Name: Andrew
Wiring question
Post by ajg1722 »
I'm now at the stage in the Bradford rebuild where I'm starting to sort the wiring, but I have a small question.
Does anyone know where the connectors between the front and rear looms is located? I've marked the point on the attached wiring diagram. I haven't got anything to go on, and at this stage, before I start, is the time to get it right.
Hope someone can help,
Andrew
nigel jarrett
Given Name: Nigel
Re: Wiring question
Post by nigel jarrett »
As far as I can remember they are under the floor half way back on the drivers side
Re: Wiring question
My very hazy recollection from Moon's braddie is that they were beside the A post.
Re: Wiring question
Bottom of the bulkhead / under the A post on the offside of the van - Chris
ajg1722
Given Name: Andrew
Re: Wiring question
Post by ajg1722 »
Many thanks for the replies.
The bottom of the A-post seems to me a bit too exposed to the elements, but if that's where the connection was, that's where it will be.
Andrew
Re: Wiring question
Bring the connectors inside the cab is my advice away from exposure .
