I live in Derbyshire, for those that don't know; for Derbyshire read "very Hilly" I started to notice a miss fire going up some of our hills. I did the obvious checked plugs, points, coil and drew a blank. But the miss fire used to start and go down to 2 plugs when under a little load, not three then two. Mulling this over I thought one carb was to rich/weak. The plugs however told a different story a nice sandy brown one.
Bowl of the carb however nasty gritty stuff not petrol as we know it. Now yes I had used 5 gallons of Tesco but the cause was a very basic one. Whilst the car had been stored the inside of the tank was open to the elements and the swishing round of the fuel scoured the surface and 35 years of muck bullets and corrosion joined forces on my tiny in line filter (before the pump) and overcame it.
Solution drain the tank swill it out as best as possible and re fill with clean petrol and put an industrial grade fuel filter in the pipe before the pump.
If I still have problems I may be looking for a brain storming session.
