Jupiter floor pattern
conrod
Does anyone have a standard Jupiter floor pattern available please, showing all the relevant measurements ?
Re: Jupiter floor pattern
From what I was told, they are all different. I made mine quite easily with minimal tools. Hardest part is fitting the part of it next to door pillars. This is a custom fit.
I intend to remake mine out of a material used for bus floors . it is lighter , stronger & fire retardant.
If some one does have a pattern , I too would be interested as a mate now has a CNC wood cutter.
Yes - I have one on an original car that will be coming out to facilitate the restoration in a little while - you can either come and pattern from it, or I could draft a paper pattern from it - I might even one have that has already removed from another Jupiter project but I will have check next time I am at the barn which is several miles from home - I am possibly going over there this weekend and could check then - where in the country are you ?
conrod
I am in Shropshire - quite a way from you - A paper pattern would be fantastic if you could do one - If posted on this site, it would be available for every member for the future - Thank you
