So here is my motley selection.
First the five different types (assuming the one at the water inlet has been extended)
Then the different sizes of lower studs.
Then of the upper studs
Then the centre stud oil feed.
Putting a ruler to the longer of the two sorts - all 3/8 BSF thread all top thread length first
No 1 178mm 17 mm 23 mm
No 3, 5, 7 125mm 18mm 22 mm
No 2, 6, 8, 9 106mm 16 mm 23mm
No 10 180mm 19mm 34mm then gap 24mm then 26mm at bottom or thread all 84mm
No 4 Oil feed bolt 3/32in hole drilled to depth 38mm then radial hole to open up. End turned down to 7mm for 9mm and finished off rounded. 23mm thread after turn down and at top end. Flat from 37mm from bottom to 12mm from top to make 5/16 in thick.
