shot blasting
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Given Name: Alastair
shot blasting
Post by Alastair Gregg »
Ladies and Gents, In the depths of my memory there is a warning bell ringing saying that certainly for Javelins and Jupiters it is not safe to shot blast the wheel rims (cos the grit gets in between the two faces and continues to wear away the surfaces, whilst the wheel revolves, even after it has been cleaned up. I may be wrong of course. But if I am right, does this apply to Bradfords too?
Compliments of the Season,
Alastair Gregg
Re: shot blasting
After shot blasting use the air gun to clean it out then a wire brush, then some panel cleaner then a few coats of paint and I do not think you will have an issue.
Re: shot blasting
Hi all,
Why not get them powder coated afterwards? It looks great and cleans up well. My ones have never given problems with sealing after being coated.
Re: shot blasting
Alastair - I have had loads of Jowett wheel rims shot blasted without issue - for the blasting media to create any problems i.e. further wear the wheel centre would have to be loose from the rim for the friction to occur - powder coating is fine if your car is a basic solid colour - however if the vehicle has a metallic paint finish then the rims will require spraying with the vehicle body colour has powder coating can not match metallic paint finishes.
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Re: shot blasting
Thank you Gentlemen,
It will be one of the first jobs for the new compressor when it arrives :shock:
Alastair Gregg
