This story is in 3 parts currently.
The chassis rebuild.
The body prep.
The body paint.
Further episodes will follow as the shell is refitted and the engine rebuilt after splitting coming back from Oulton Park
Apr 6, 2017
So next in the queue is this little Jowett Jupiter - Tubular chassis of ERA design (English Racing Automobiles) clad with a largely alloy body, all round torsion bar suspension, 1500cc water cooled 4 cylinder Jowett boxer engine, 4 speed column change gearbox - Class winner at LeMans in 1950, 51 & 52 - This particular car has been with the current owner for the last 49 years who has raced / rallied the car in no less than 27 countries
In race trim
Now with me for a complete body restoration - whilst the car has always been continually maintained this is the first full rebuild in the 65 years of the cars history - the chassis has already been rebuilt by the owner who is just rebuilding the engine
These are a rare car - only 830 built out which circa 350 survive today
The steel bulkhead requires quite a bit of work (steel) & new sills prior to setting the rear shroud / door apertures up - I will post more updates as progress is made
Apr 12, 2017
Commenced the structural repairs on the offside
Removed the sill section & tidied the door pillar up (note the brace frame to temporary hold the shell structure in place)
Patterned up for the lower section of the bulkhead return prior to cutting it out
Floor pan repair & body mounting bracket welded in
Bulkhead return repair panel in the making / trial fit
More to follow tomorrow
Apr 13, 2017
With the bulkhead mounting done I could get the car up off the floor and on to stands - care is required however as although the chassis is strong - they do flex so an additional pair of stands is used under the centre of the car
Bulkhead return panel welded in
Cleaned / dressed back
The lower A post is available as a repair section but it takes a lot trimming / fettling to obtain a decent fit - what is more is the fact that these were handbuilt cars and no 2 are the same - the A post covers the front end of the sill section and the same applies to the B post
Which is in a proper state with patches over the top of patches
Only one thing for it - chop it all out - but only after much careful measurement / alignment & offset marks were placed - I also have the bracing to act as a jig for the refitting
I will salvage the B post with some repairs to lower section
Rear chassis - body mounting point pending a exit to the scrap pile
And can start rebuilding from this point
With the rear mounting point spotwelded in I can trim / trial the sill section for a fit
With a some minor fettling in the morning the sill should make a good fit - I only intend to clamp into place and then trim the a post repair in and around it - same with the B post - at that point I can drill the holes and mount the bottom door hinge to the underside of the A post repair panel then hang the door and look at door gapping (notorious for poor fitting on these) - do any adjustments - recheck before welding anything up - the sill determines the door width as it joins the front bulkhead to rear frame of the car - hence it's critical to get it right at this point - otherwise the doors just don't fit !!
Apr 14, 2017
Sill panel fettled and refitted temporary with cleco pins - then sorted the inner panel on the B post
Once sorted I refitted it but only to the bracing jig - I do not want fasten it down anywhere else as it will more than likely have to be adjusted to obtain the correct door gapping
I will sort the lower section of the B post adjacent to the sill once I am happy with the door alignment / aperture gapping
Now starting to take shape
So is the scrap pile
Then started the A post repair battle - I have had to over trim the cut out around the sill section in order to obtain a slip fit under the existing A post which I have joggled the side panels upon for a rebated weld and likewise on the external face but overlapped rather than underlapped for additional strength
Measurement wise it has come in perfect but still needs a little more fettling to the panel - and will need the overcuts around the sill section letting in / making good - once I am happy with the fit I can temporary secure the panel - drill the base for the door hinge and hang the door to see where we are with the door fit which will hopefully get done tomorrow if I can find an hour or so
Apr 17, 2017
Latest progress - lots of adjustments / fettling in order to align the door aperture and to fit the lower door hinge
A post repair section removed / reworked / refitted several times over - minor adjustments made on each occasion
Likewise for the door
Until I got to the point that the bottom door hinge could be fitted - this fits under the bottom of the A post repair section which has to be drilled - these are hand built cars and nothing comes the correct shape /pre drilled etc - it all has to be made to fit
Rear shroud to the lower sections is fatigued with splits & corrosion and will have a new section formed & welded in
Quite a few shims / packers had to be placed in order to get to this point
So tomorrow I can commence the task of taking the A post repair back off along with the rear shroud and start welding the sill insitu along with the rear section to the floor braces
Still some fettling on the front aperture against the A post in order for the correct door gapping to be achieved - but this is me being picky - the apertures were never this good when the cars left the factory new.
Apr 18, 2017
Spent a little more time sorting the door aperture out before doing some final offsets / measurements & checks
Took the door back off and removed the sill & B post
The old sill section was open at each end so just used to fill with all the crap thrown at it by the wheels
To combat it happening again I welded blanking plates to either end of the new section
Sill refitted and commenced welding up carefully to avoid any heat distortion
A post repair starting to go in
Then the B post and a clean back of the welds - the door was refitted several times to ensure the aperture gaps remained consistent
Once cleaned up I then refitted the door and the rear shroud - all ok so off it came again and I put the dressed welds / bare metal into construction primer
I have some repairs to undertake to the bulkhead in the morning and then the car can come back off the stands and be turned around in preparation for the structural repairs on the nearside
Apr 19, 2017
Bulkhead repairs required for various reasons
Aerial & other drilled holes
Rot to the underside of the windscreen aperture
Poorly repaired bonnet hinge aperture for the hinge box.
Over plated rot that I will cut back out
So with said repairs sorted I put the car back on it's wheels pushed it outside
Gave it a good blow off with the airline and lost all the loose dust off it - had a good sweep up in the workshop and put the car back in for the work on the nearside
Virtually a repeat process of the offside
Plenty of weak areas & hidden grot
So - onwards we go - more to follow soon
Apr 20, 2017
Not too much done today as I had other work that got in the way, none the less got the grot at the front chopped out
Made up a couple of body mounting brackets utilising the old one as a pattern
Then got the front one spot welded in before packing up for the day
Apr 22, 2017
Floorpan repairs & footwell return panel repairs completed to bulkhead
Rear body mounting replaced along with bracket for connecting rear support framework
The rest of the work is a duplicate of the offside so just going to touch on these has progress is made rather than go into much detail with them.
Sill trimmed in and temporarily placed
Quite a few hours spent trimming / letting in the bottom of the A post repair before getting it to where I wanted - now fastened temporarily to allow bottom door hinge to be centred & drilled - then the door hung to allow B post / door aperture setting - more to follow tomorrow
Apr 23, 2017
B post grot removed, repair sections tacked in and then refitted temporarily to the car
Then hung the door which initially fitted ok to the rear but very poorly at the front
Spent several hours making adjustments to the sill, A post repair & B post
Slowly making progress but still way of alignment in both the aperture gapping & side profile
The lower 300mm of the rear shroud will be remade both sides are suffering from corrosion and are weak at the point the rear wing bolts up to it
Crease to the lower section of the door was throwing the side profile & alignment out
But eventually I got to the stage where with the bottom hinge drilled and bolted up to the A post repair that the door hung / opened and closed close to tolerance - still some further adjustment to be had but I need the sill welded in and the A & B posts tacked to the sill before I can achieve the adjustment - Sports roadsters of this era are notorious for poor door & panel fits - getting them right at the restoration stage just take a lot of patience
Apr 25, 2017
Door, repair sections & sill back off - blanking plates fabricated & welded to sill ends and everything cleaned up / painted with weld thro' primer - sill going back on
Lower section of B post patterned up & repair sections made up
With the sill on the B post was trialed for fit again
A post repair ready for tacking up
Door refitted & along with rear shroud panel and all aperture gapping / door operation trialed / corrected as required
With just some very minor areas of welding left to do on the main shell structure the temporary supporting framework between the A & B posts & cross bracing could now be removed
This allowed access to weld the rear inner sections around the overdrive & battery boxes - these had been cut to part the rear frame from the centre section when the car was stripped so that everything could be sent for shot blasting
I will complete the welding on the frame structure today and can then make a start on the outer panels
Apr 25, 2017
Side return on the bulkhead had a few non original bolts through it - I removed them and found that the spotwelds had failed on this length and the bolts had been added to keep the panels flush - so cleaned the panel & flanges up
Turned the power up on the spotwelder and rejoined the panel to the flange then welded the holes up left by the bolts
Rot to the underside of windscreen mounting - cut out
Fresh metal let in & cleaned up
Again a weak repair had been made to the bonnet hinge box aperture
Cut out and a double skin repair fabricated and let in
Aperture holes for previous mountings to the horizontal bulkhead panel
Welded up & cleaned back
Structural repairs complete
Used the airline / blowgun to remove the loose dust - quick mask off of the chassis tube and applied construction primer over the new / reworked areas
So I can now crack on with the outer panels
Found the body number on the bulkhead - Jowett numbered all of the production runs in this case '630' out of the circa 830 cars built
May 8, 2017
With the main structural work sorted I commenced repairs to the lower front sections of the rear shroud
With the repairs welded up - I cleaned the underside of the shroud panel off
With a multiple of panels to prep - I like to stop of top of the process rather than do one panel at time only to
recommence the same process again on the next panel I always try to stage process 2 - 3 panels at a time as this saves with drying times - one can be drying whilst the others are being worked on and I just keep advancing the process in rotation - so next was the underside of the bonnet (which had been the subject of damage via a engine fire)
Took a while but carefully removed the support frames so that these could be shotblasted
This now allows unrestricted access so that I can prep all of the underside - a couple of edge splits in the alloy need welding up and there are numerous dents / creases that require some careful hammer & dolly work
The face side of the bonnet although largely stripped of paint have had a good work over with the DA / P80's
Revealing a patchwork of redish colours - the car has been bright red for the last 50 years + however it would now appear that the car was originally a maroon metallic - spoken to the owner and he is all for adopting the original colour scheme - so I am currently doing some research into a paint formula for 'Jowett Maroon Metallic' which apparently is no longer available but I will find a way somehow
Meanwhile the rear shroud was treated a session with the DA to remove the last of the paint
Plan for the next week is to concentrate on the rear of the car - get the shroud refitted to the steel work - refit the rear wings temporally and work / correct the profiles on the car from the doors back
May 9, 2017
Cleaned up / prepped the underside of the rear shroud - this is nigh on impossible to freely access once fitted
Then into primer
Then Satin Black
Fixed new frame packing to the steel work
Then on with the panel
This can be adjusted in the morning for aperture fit prior to flanging over and applying the permanent fixings (riveted)
May 10, 2017
Started to fasten the shroud panel up commencing at the door apertures
They were pop riveted originally at the factory the holes in the outer panel have to be carefully countersunk to ensure that once the head is cleaned back there is still enough of the rivet head existing to retain the panel
With the door aperture edges fastened up I could now close the flange edge around the rear bulkhead - this is also riveted into place
Then fastened the rear section up again riveted but a few bolts come into use on the underside sections
Next was to make up a stay bracket for the lower front sections - these need to be strong as this panel also supports the rear wing which bolts up to it
I fabricated these out of some 3mm equal angle that I cut down / shaped as required
Welded tab helps locate the new bracket prior it being welded to the inner / outer sill flange - once in place I drilled two holes through to locate the fastenings
Rivets to the bulkhead ground back - carefully!!
Now I have the panel firmly fixed I can make any adjustments and do some final panel beating prior to commencing the profiles
Typically the flap for the spare wheel does not fit - the aperture is way too tight so some judicial use of straightening /widening implements will be put to use tomorrow
May 12, 2017
So with the frame having come off the car / shotblasted / powder coated etc - add to this that the car has certainly had life and has been the subject of several minor rear end shunts in it's 65 year life - so time for the said judicial use of widening implements
Few adjustments with the hinges and some reshaping of the apertures / flap and we have a result
Need to close the aperture gap up a little but I can take this into account as I work the profiles
With the shroud panel now fully fitted / fixed in place I could undertake the final shaping on the panel
Looks drastic but by carefully working the panel with a bodyfile the high / low spots are highlighted
From here I can improve the panel profile by a combination of dressing down the high whilst tapping up the low areas - Tapping down is easy from the outside but the access to the underside is now restricted by length / size of the panel / steel underframe / petrol tank etc - my weapon of choice is the long curved spoon dolly seen in the pic - could just about get to everything with this and by tapping up whilst eyeing in the shallow / depressed areas I achieved a decent result - just went back over with the bodyfile prior to applying the first skim - care has to be taken with the bodyfile though - you can't go hell for leather with it otherwise you would soon be filing through the alloy surface of the panel
Side repair sections turned out pretty well once cleaned back & profiled
So on goes the first of the skims - it is going to take several to get it correct but there will be probably less than 2mm in thickness overall once completed
May 12, 2017
Not too much done today due running around dropping off / collecting parts / materials etc but managed to get the the offside of the shroud skimmed over and the guide coat applied
May 16, 2017
Not too much done today as I have a modern in for repair which is hindering progress but managed to get a couple skims blocked back / reskimmed and the profile detail has started to come together on the nearside
May 17, 2017
More profiling on the rear shroud - along with a ash packing piece cut, shaped fitted to aperture edge of the spare wheel flap
Fits between the supporting frame and the alloy aperture edge of the shroud - picture taken from the rear of the panel
Skim number 4 on the nearside and the offside ready to accept skim number 2
May 18, 2017
More progress with the profiling on the rear shroud but I won't bore you with that - Bonnet underside fettled
New side flange return panels made up from 1.2mm sheet - the old ones are wafer thin - I don't need to rebate on the new ones as this was for a old style lock to the bulkhead - I will have to fabricate some type of locator to the lower bulkhead / A post though otherwise the edge of the wing is venerable at speed to moving out - it is very thin at this point and there is not lot of strength in it
Bonnet support frames, flange return panels & underside of bonnet prepped and ready for base primer
Primed (just) as the pic was taken
May 20, 2017
Nearside rear shroud & side panel now getting close to final profile
Final self levelling glaze applied in order to reduce minor undulation
Happy with the door gapping at the B post
Bolted the rear wing temporary to mark up new repair panels for drilling of holes / mounting bolts
Removed the wing / drilled holes and rehung the wing - it gives me a more solid base on which to work on it from whilst also a better prospective of the profiling can be maintained
It's had it's fair share of battering's during it's life
Removed the rest of the paint with 80's discs on the DA
Then spent some time with the hammer & dolly straightening the wing up ready for profiling
May 21, 2017
I do re-anneal alloys that are badly distorted / dinged otherwise as you start to straighten the panel up the alloy will start to crack / stress - especially old alloys that were not of that good a quality when new - one of the larger problems with alloy panelled cars of this era is that the effect of dissimilar metals were not taken into account when the car was built - so where the wheelarch on the wings are formed over a steel wire bead - 65 years on and the alloy edge of the bead is badly corroded in some areas of the panels - behind the scenes Keith who owns the car has been letting in new alloy sections into the panels where required - he opted to undertake this in order to keep his restoration bill in check - fine by me so long has the repairs are of a good enough quality .
Had an hour or so on the profiling of the wing today - needs a lot more yet
May 22, 2017
When working large areas I always highlight with pencil high / low areas or areas that may require rework or a new hole drilled through - it makes an easy job of reapplying the filler skims rather than having to remember the multiple areas - when working with multiple of panels in order to keep good work progress i.e. commencing on one panel - have another panel at a mid stage whilst bringing a third panel to completion - has I complete areas I drag a diagonal line / cross hatch across them with pencil has an indicator that I am happy with that areas profiles and I can move on to other areas on the same panel or to another panel - you can also say that I use it has a mind set on large projects - the more lines you see the closer to the finish line you are - This is important when you are plugging away at profiling every panel on a vehicle which may take several days / weeks - it's monotonous, laborious, can be quite tiring when constantly working the profiles by hand and can appear never ending - it is very easy loose your way / loose interest in what you are attempting to achieve - allow this to happen at this stage and the paint will highlight undulating panel profiles and lack of care / attention to detail. To view the panels come to completion is the tick in the box that you need to visually see - Its a 'Matter over Mind' vs 'Mind over Matter' thing that works for me (also how I was taught by the master of his craft when I was apprenticed) - I have never found a better way of doing it so It's stuck with me for the last 40 years.
May 23, 2017
Still plugging away at the rear profiles
Rear half of the wing completed
The join between the rear shroud and the wing has a wing piping fitted when painted, the lamp aperture is not critical as I am refitting the original lamp cowls to the wing / shroud - to date it has run with rubber insert / lens type fitting similar to the classic mini front indicator lamps
Then removed the wing so that Keith could crack on with the welded repairs on the forward arch edges
Meanwhile on the offside rear shroud the profiling continues
wonder if I can interest the Tate Gallery in my panel profile jottings
Started to shape up the rear flap
Getting there - offside shroud panel now in glaze - hopefully get this completed tomorrow in between everything else that I got to get done
Glaze is a final filler product - still mixed with a hardener and applied like filler with a spreader - however it is more viscous in form - self levelling and unlike filler flows out - it is used in thin skims to eliminate undulation in work areas - can be applied very thinly if required and can be sanded / feathered back to a virtual transparent layer - there are several brands on the market - personally I use U Pol 'Dolphin Glaze' - it can be seen in the image as the greenish looking covering on the panel
Jun 2, 2017
Back to the profiling after our short break away to Scotland
Offside rear wing rehung and profiling to the front section of it underway (rear half already completed)
Profiling to the rear nearside of the shroud completed and the nearside rear wing hung
Much like the offside rear wing the nearside has also seen much activity and requires a fair share of reshaping
Jun 5, 2017
Work continues to complete the profiling to the rear of the car
Noticed that the bottom of the spare wheel flap was not straight
Checked the interior profile and it all looks original
Researched with a couple of images to check and it would appear that the lower flap edge is covered by the number plate on most of the Jupiters
so I am going to leave it as it would appear to be the original profile
One more skim should do it
Progress on the re-profiling of the rear wings continues
Jun 8, 2017
Update from the last few days
Spare wheel flap profiling completed
Reprofiling on the rear wings complete on the nearside and 90 % complete on the offside
Rear lamp housings are missing and are very rare for this car however - the Jowett Javelin housing is similar but based on a largely flat surface of the Javelin wing
So I stripped a pair of Javelin housings (which are abundantly available) - had to swap the handed sides over nearside to offside & vice versa otherwise the lamps when fitted to the housings would be on a inwards angle rather than square - the other issue being the fit to the wing
With some careful reshaping a decent fit was obtained
Piping bead will be fitted around the housing (as factory original) once painted to prevent the housing from biting into the paint
Threaded studs were welded to the rear of the housing and the rear wing & shroud drilled for fit
Start was made on straightening the nearside door up and the first skim applied
Bonnet centre section assembly going back together
Part riveted / part bolted to rear & centre frames
Front edge support fitted
Bonnet fitted many times - hinges altered / raised / lowered to attempt best fitting to rear edge & bulkhead
Gapping getting there
But the offside fit is miles away
What I am aware of is that at a early stage in the cars life it was involved in a heavy impact to the front offside - some of the chassis sections to the front offside corner have received repair - these repairs are to a good standard and the chassis is straight but the repairs are obvious if you know what to look for - the bonnet and front wings were also replaced at the same time (these carry the body number 94 whereby the remainder of the car carries the original body number of 630) - hence the bonnet is a second hand panel and has never fitted that good on the offside (remember these are hand built cars - the same panel from one car will not necessarily perfectly fit another) - I will have to make some further adjustments in order to get a decent fit here - more to follow tomorrow
Jun 9, 2017
More progress - spent just about all day taking the bonnet on & off - making adjustments / alterations every time in order to better the fit
Happy enough with the central aperture gapping between the bulkhead / rear edge of the bonnet - took several attempts to get this right so that either of edge apertures did not catch upon opening / closing - the nearside radius edge of the bonnet will require some welded repairs where an existing welded repair has opened up whilst I was reshaping the edge profiles to match that of the bulkhead
Bulkhead on the nearside is slightly higher than the bonnet - I will have to shim the hinge slightly to correct this - the bonnet is also deformed on this edge so some skimming will be required
The offside radius edge is the worse area - some previous repairs to the edge have left it somewhat deviated from the original profile line - this will need to be bridged some 10mm with a welded repair to gain the correct profile
Some minor closing up of the bonnet hinge boxes will be required when it comes back off
Couple of pics from the front
Meanwhile the offside rear wing profiles were completed
That just leaves the offside rear light housing to complete and the entire rear of the car is ready for going into a polyester spraying filler
Jun 11, 2017
Bolted the front wings on to determine the work required on the bulkhead / wing / bonnet aperture gaps - due to the amount of filler that was removed from the wing edges we knew that they were not going to be anything like what they should be
Close up image of the issues
This is the best that we could achieve without compromising the fit that we have over the top of the bulkhead with the bulkhead / bonnet aperture has this dictates the datum / starting point to work from - The bonnet had to be fairly heavily tweaked on the offside front to correct the profile with the front of the wing & chassis cross member (this corner had previously visited one of the tyre walls at Donington Race Circuit several years ago) The aperture gaps will have to be closed by adding to the wing & bonnet edges - I need to get to a 5mm gap and currently it's 10mm + I plan to do this with some 4mm alloy rod welded to the edge and shaped to finish by the time the weld is taken into account this should do the trick - some minor work of straightening up the A post on the nearside by running a small MIG bead will also be required but only approx 1.5mm thick - took most of the day to get this point
The rear offside lamp housing was fitted and just requires some very minor finishing to the profiles
Jun 11, 2017
Only thing done today was to open out the inner apertures for the rear lamps and trial fit them
Jun 13, 2017
More progress - sorted the deviation on the A post with a bead of MIG weld run down it & dressed back - also blanked the trafficator slot off - just need to lead load the area prior final profiles
Offside door lower inner panel was suffering with rust perforation
Removed
New panel made up & let in
Door is now rehung - I just need to adjust it slightly to obtain the best closing fit
Originally there was no provision made for this at the factory - I just have to do my best with what I have now - so the repair to the inner door frame where the outer alloy skin meets the steel inner skin - I have primed the steel and applied a sealer either side of the panel - I will use brass nuts / bolts / washers to refasten the wings - there is also a piping bead between the wing joints, some panels can be protected with the use of a non conductive / insulation tape - but just about everywhere on the car there are alloy panels abutting the steel frame work of the car / chassis - next to impossible to prevent unless you started again from scratch
Jun 15, 2017
Spent quite a bit of time sorting out the bonnet location stops and made some new brackets up for them - what was there before was laughable - used some sleeved suspension bushes - I had the bonnet spaced / propped on a couple of wooden blocks / packers from the chassis to work out the height that I needed it sat at
Made up some L brackets from some 3mm plate - drilled for the bush to locate to - slotted the bolt holes to allow for adjustment
The bonnet is then retained down by a screw type hook - which are fitted at the front just to each side of the location stops that I have fitted
Now need to sort the location stops on the wing sides - originally budget locks were fitted at the factory - some Jupiters have been retro fitted with external keeps / locks / locators - the big danger with these are that they get forgotten about - the front bonnet locks get undone and sides don't - the bonnet gets opened and no end of damage results to the wing panels - so I opted to use the same idea has what I had for the front stops - made up some brackets and welded them to the side of the A post - allowed for some adjustment and just drilled a hole in the closing plate - It's all a very simple / primitive set up but very typical for a car of this period
Took the wing off and cleaned / dressed the mounting flanges up - also dressed the edges up and then refitted the wing - removed the remaining paint with the DA - started to dress the numinous dents & scrapes up but needs more work yet - aperture gap to the A post now looking a lot better but again still requires more work
Jun 16, 2017
Sorted the offside front wing - removed cleaned up etc & refitted - checked the aperture gapping with the A post and adjusted the stop accordingly
I could now fit the new front cowl sections (between the lower front wing and the bonnet)
Image from the front with all panels built / fitted
First skim applied
Sanded back and ready for second skim - bonnet will require a lot of work has it has been the subjected to a previous engine / carb fire
Jun 20, 2017
Had to move the Jupiter outside as I need the workshop space to sort a repaint on a Range Rover roof so dropped the wheels back on it - this is something that I need to do anyway has the wheel clearance in relation to the wings needed checking
Like a sauna in my workshop for the last few days well over 30c today and still loads of profiling to do - some long flat areas on the front wings & bonnet - I like to do my sanding dust free so use a vacuum extraction and a specialist abrasive - it's by far not the cheapest way to do it - but is makes it so much easier than breathing in / bathing in tons of filler dust - I have several sanding blocks + 150mm DA / dual action sander electric powered all on auto on / off with the extractor - my longer blocking to date has been done by hand with this
But as said above still loads to do so time to purchase a new toy
Connected to this
Produces this result in 5 mins instead of the 30 mins by hand - I wanted electric powered as air powered is inefficient, but also had to have vacuum extraction on it so it's quite a rare beast in turn £££ more than any other flat bed sander on the market !
So cracked on and got a bit more done
Bonnet is made up of 11 separate sections which were gas welded at the factory - some of the original seams are still visible - very little deflection in them but they all require a slight skim to obtain the correct profile
Jun 21, 2017
More profiling today and now starting to take shape this is the fourth skim - it normally takes between 5 to 8 skims to get panels of this degree returned to the correct profiles
Jun 22, 2017
Still plugging away - a lot more comfortable with the temperature drop though - lower 20's c today in the workshop
Image probably doesn't look much different from yesterday - but front wing and door on the nearside now requires very minor works to complete the profiles
Checked the front side lamp for aperture / profile fit - originally the side lamp now converted to front indicator and the side lamp relocated to the headlamp
Profiling works also migrating to offside of the bonnet
Also hosted a visit from Sid my quality control inspector
Jun 23, 2017
So on the profiling completion list for today
Nearside door
Nearside A post & bulkhead to centre of car
Nearside front wing
Meanwhile the nearside & centre sections of the bonnet are on their fourth skim
And profiling works commenced on the offside front wing
Jun 26, 2017
More done - bonnet centre section & nearside flute 90% completed just requires the glaze sanding back in the morning
Offside bonnet flute well on it's way and offside front wing on it's second skim
I appreciate that on viewing the images that the bonnet / front of the vehicle in fact all the vehicle looks like it's covered in filler - well it is but remember this is merely a thin skimming in order to correct the profiles nothing in excess of 3mm - 5mm deep has been applied - the panels are 95% original and in being so are 67 years old - had numerous repairs and covered well over 500,000 miles - replacements are not available unless you were willing to pay something in the region of £20k to have all new panels made - so it is the only option - I work no different than any other competent vehicle restorer other than the fact that I don't mind demonstrating how it's done
Jun 28, 2017
So one bonnet with the profiles completed
Profiling is well advanced on the offside front wing, A post & offside bulkhead
And a start made on the offside door
Jun 29, 2017
Wing profiling completed
A post & bulkhead very close to completion
Offside door also well on it's way and will get completed in the morning
So with all the outer panels just about completed the wings could start to be removed to allow the flange edges to be finished and the undersides to be prepped, treated & painted
I will make up some hinge location templates for the doors in the morning prior to removing them to allow access to the door & sill apertures so that they can be prepped
Jun 30, 2017
Prepped the underside of the nearside wings and then applied a seam sealer to the rolled edge on the wheelarch where a steel wire froms a brace for the edge - the sealer will prevent crud / water from filling the rolled edge and providing a base for the wire to rust - The front wing will get a stone chip applied to it prior to the paint being applied (the front wing undersides are seen when the bonnet is lifted) whilst the rear wings will be subject to a Dinitrol treatment - the alloy that the panels are formed from is pretty soft and is easily dented by small stones thrown up from the road wheels so the underside of the wings needs something on them to prevent this
made location templates up for the nearside door hinges & striker plate for the door catch - this will easily locate the hinges when rehanging the door after the car is painted and avoids damage to the fresh paint
Door removed and the sill drilled for the rivet nuts which in turn will retain the floor section which is plywood (common for the period of the car)
Apertures prepped and profiling commenced
Meanwhile the offside door is virtually complete just needs a little rub over to complete
