Vintage exhaust
Vintage exhaust
Having problems finding an exhaust fabricator who can supply 1.25 inch mild steel pipe. Does anyone know of an off the shelf system which could be adapted for a vintage short chassis? The Morris Minor exhaust looks promising!
Re: Vintage exhaust
Hello Ken.
There was a lot of discussion on:- Jowett Kestrel Rebuild & Restoration - Julian's post of the long-running saga of his pre-war Kestrel restoration.
e.g. - Jan 16th 2015 (Ian H): Jan 13th 2015: May 22 2015 etc.
Perhaps a call to Julian will help.
I put 'morris' in the search box of the first page of JowettTalk and a lot of posts came up. There may be some other ones about exhausts.
Re: Vintage exhaust
Thanks Tony, it would appear that if the vintage Y-pipe is the same bore as the pre-war (I will measure) then the Morris Minor system could be adapted and is readily available. I will report back once I know for sure.
BarryCambs
- Given Name: Barry
Re: Vintage exhaust
Hi Ken
I cheated and went for a side exit exhaust, just in front of the rear wheel, but it might be a problem on a short chassis. I had problems due to having the wrong engine, so the standard Y pipes wouldn't fit. I was also a bit worried by the twist on the chassis putting a strain on the exhaust, but solved both problems by using flexible exhaust connectors, which might help you join the various pieces of whatever you end up with. I found on ebay some really quite neat ones with proper sleeves. I slotted the sleeves and used a smear of sealant and some decent band clamps and it looks a treat. Someone did later point out the car is missing it's side skirts, so normally you wouldn't see the system anyway! When you order, you select a length and diameter which helps and I think I only paid 6 or 7 quid which seemded pretty reasonable.
Re: Vintage exhaust
I used a Morris Minor pipe when I did mine - the bends had to be relocated and I made up a Y pipe using the flanges that came with the car.
The whole thing is solid throughout and I hung it with flexible ;inks onto the chassis cross members.
Itg sounds OK too.
Itg sounds OK too.
Re: Vintage exhaust
Interestingly enough, if the vintage exhaust is the same as the pre war. I used a silencer from a Robin Reliant on mine it was same and shape and near to the size of a pre war one.
Re: Vintage exhaust
Hi Alan, that's what Geoff told me he used on his vintage, but when I enquired with a chap on ebay he thought the pipes entering the silencer were 38mm which would be too big - perhaps he was wrong! Would you know the actual size of the pipes on your silencer?
Re: Vintage exhaust
A chap at Regis Exhausts has got back to me with dimensions, so I think I am going with the Reliant Rialto silencer and Morris Minor tail pipe, as it looks like it might have the right geometry over the rear axle. I just hope I can join them satisfactorily.
Re: Vintage exhaust
Just an update - I used a Reliant Rialto silencer from which I had to cut off a good 5 inches off the exit pipe to link up to the Morris tail pipe. That also had to be cut lengthwise, but fits beautifully over the rear axle. In the end I used an internal sleeve made from the 4 inches i removed from the Y-pipe to join the silencer to the Morris rear pipe. I now have to find some hangers for the tail pipe and a short length to put in the end. The standard short chassis had a tail pipe which carried on at the same sort of angle I've got, but an original pic of the Sports shows it coming out nearly horizontally, so I will need it with a bend.
