The members with email addresses in the NZ list should now have access to Jowett Internet Services. A small step to single sign-on.
You can check your email address is in the list correctly by signing on to jowett.net. Note you currently need to register here if you have not done so already. This registration is different to JowettTalk and JowettGallery currently but they will merge eventually.
Membership list
Moderator: Keith Andrews
Membership map
The map of all JCC NZ members is now available based on November 2015 list, so those that looked at the 2014 map previously displayed may like to check the changes.
It now also contains the overseas members that were not there previously.
The map attempts to highlight new for 2015 members. As the spreadsheet was not in a suitable format to load into the database, I had to manually input the data and compare to last year. There may be a few mistakes so please advise if there are.
I also had to find and extract some Apple injected special characters that prevented display of some data. These also prevented the map from showing but I added code to stop that happening. A simple job made difficult!
The map can be accessed after log on to JowettTalk. Click the Jowett.net button on the ACCESS CHECK page and choose First Aid from the SERVICES panel. If you have the necessary privilege (that is your JT registered email address matches that in the membership list) you will see a 'NZ First Aid Map' button.
Enjoy and use to get together.
