LUCAS VOLTAGE REGULATOR 12V AND A 6 V
Greg Jackson
- Your interest in the forum: JUPITER HDM 949, MG ZT 260 4.6 V8, ROVER B.R.M, 1935 WOLESLEY WASP, HARLEY DAVIDSON XR 1200,
Selling, Lucas Regulator box 9 pin 12 v £40, and a 6v Regulator box 9 pin £40. Greg 01614373916
Re: LUCAS VOLTAGE REGULATOR 12V AND A 6 V
Now that is a coincidence. Jack had followed the wiring diagram in the handbook and incorrectly wired up the regulator as the handbook was 6v and the CC was 12 v thus using a different regulator. Although both 9 pin the terminal layout is completely different, only the dynamo wire stays in the same place
So after some thought and a new terminal map I rewired the offending regulator. Luckily we had not conected the dynamo when we started the engine a couple of days ago..
