I am hoping to have access to a spare crankshaft for my 1930 Long Four, but I am not sure whether it is of the correct type.
As I have not stripped my own engine I don't know what to look for.
I assume that all the two-cylinder cranks are generally similar, but - for example - I assume that Bradford ones at least are different in that they have provision for a fan belt pulley at the front end.
What are the differences between the '20's and 30's cranks - apart from the provision for pulleys on those cars with belt driven fans and dynamos?
I suspect - but don't know - that the balance weights may be different, the flywheel mounting, and possibly the crankpins (hollow?).
Any/all advice gratefully received.
Spot the Difference
Spot the Difference
Re: Spot the Difference
I went to the parts store in Christchurch NZ where they must have had 100 Bradford crank shafts. They had been methodically testing these with the tap, ring and listen test. They found well over half were cracked. Lots of scrap metal!
So, Tap, Ring and listen before committing!
Seems like a good idea, but what about the differences?
I suppose stationery engines could also be an additional variation?
More news: -
There are TWO 2 cylinder cranks but they are slightly different . . .
At the front end on one there is a MALE thread about 3/4" diameter and quite coarse (possibly BSW?).
On the other there is a FEMALE thread about 1/2" diameter and noticeably 'finer' (possibly BSF?).
Does this shed any light / confusion?
