Jupiter Oil Cooler
Andrew Henshall
Jupiter Oil Cooler
I want to mount an Oil cooler similar in style to the later Bowman type in the original location on the front of my Jupiter's rebuilt engine. Clearly I'm not going to be able to find an original Bowman cooler, but if anyone has a sketch of a Bowman showing approx dimensions or even a photo they could post that would be great.
I guess I will find a 5 or 7 row cooler off something else that will do - can anyone suggest possible sources from other cars (make/model/no. of rows, etc) and potential suppliers? If you fitted one in this location, what did you use for an Oil cooler for your Jupiter?
Kind regards,
Andrew Henshall
Secretary & Registrar - JCCA
Kind regards,
Andrew Henshall
- Given Name: Drummond
JUPITER OIL COOLER
Andrew, I have fitted a 13 row SPEEDWELL cooler. It works very well. Will take a few photos and e-mail them to you. Please confirm best e-mail address to send to.
Regards DRUMMOND
Regards DRUMMOND
JUPITER OIL COOLER
Andrew If you sent me an e-mail then I have mistakingly wiped it. Can you resend so I can e-mail the photos to you
Drummond
Drummond
paul byrne
Andrew Henshall
Bowman Oil Cooler
Thanks Paul, I will be in touch via pm.
Cheers
Andrew
Cheers
Andrew
Andrew Henshall
Bowman Oil Cooler
Per my original post, as I don't expect to find an original Bowman oil cooler for sale anywhere in the world, I will be adapting something (s/h or aftermarket) to fit so that it looks as close to original as possible. Hence I am looking for something with 6 tubes, and will fabricate brackets and make fitting to match the original.
