The one in the pond that drives the fountain and 'creek' pumps 3500litres/hr at a 1.5 m head
Also a yr or so ago was thinking about the old VW beetle...heat box off the exhaust
A large tube around the exhaust pipe, open at the front.
Then 1 or 2 ducting tubes that run up thru the floor with outlets under the seats directed at the feet...the hot air would go past the feet up under the dash then spill out onto the passengers........maybe...in therory
I just dosent work while the veccle is stopped unless a fan is put in the system.
Or if one desides to go 4x4 off roading
