VOSA does police the system, and instead of prosecution, typically they find the rogue traders and remove their licence to issue an MOT cert. They have published policies on these things. It does happen quite a bit, they take a car which has just come out of the garage with a cert and put it back on the ramps and retest it. Obviously some things are open to a bit of interpretation, but failing to spot obvious safety issues that are clear fails can put the tester personally in hot water. In most cases an MOT tester losing their ability to issue an MOT cert probably puts them out of a job.Forumadmin wrote:The point about any modification is very important as this needs to be interpreted in law and by insurance companies. These days it can mean not using a manufacturer's certified part or even not fitted by a maunufacturer's certified mechanic. It is obviously rediculous when it comes to older cars; but there was a push by manufacturer's to push this through EU legislation.
I think in the UK an MOT tester has never been prosecuted for passing an unfit vehicle as it is understood the certificate does not consitute roadworthiness. There have been some rogue testers who have been prosecuted but that was really for fraud.
Vehicles are one lucky area where the dreaded standards and CE mark debate seems to have been kept at bay - for example a car is sold as standard with a CE mark in the EU, but if you fitted any modification whatsoever to it, like a pattern part, then it no longer holds the CE mark because it has been modified. Insurance companies seem to be ok with people doing that, and declaring their modifications, but in many other industries if you modify or interfere with the complete system then you can find organisations like the HSE make life very difficult.
