It has been a busy few weeks. The boot has come out, Keith did some welding up of damaged sections, and added strengthening plates in the corners which seem to be a bit of a weak point with heavy bags in the boot and rough roads - now it should be very solid. Keith repainted inside and out, and today I managed to get it refitted - various screws had worn through and have been replaced.
After much discussion, including some debate about the relative strength (or lack of) in the current eyelets for the harnesses, we decided to fit something strong enough to withstand a bit more force - as such U bolts were fitted through the back of the cockpit and through the crossmember in the top of the boot. It is now very secure and would require a huge amount of force to even deform.
The harnesses went into the washing machine yesterday, huge amounts of oil and grime have hopefully been removed to do the rest of the work on the interior justice. The car will have two matching harnesses for the first time in some years, and they should look good against the new seat.
The work was set back a little bit by one temperamental MX5 head gasket, which took a few days to get sorted, all put back together and surprisingly straightforward to do for a modern car. Only for last Friday a drive around the M25 and it overheats again and won't restart. Head gasket suspected probably because it had warped or cracked and not skimmed the first time. Only to find that it was a hose below the thermostat which was removed doing the cambelt and not refitted - it had leaked water when the thermostat opened, running the system low on coolant and causing overheating. Refill the system and off we go again, no problems. I wasn't looking forward to doing the head again on that one - always unexpected jobs come along while you are trying to get things done!
Yesterday we made progress on various fronts, the overdrive has gone back on to the car for a busy summer on the road - Keith is planning various overseas trips, plus the rally in Wales, the Silverstone Classic, and quite a few other events. We are missing a small but important part, but no doubt this will turn up somewhere.
Last week the carpet went off for cleaning, and after some professional attention they've managed to remove most of the oil and dirt, it almost looks respectable
New carpets have been made for the sides of the footwell, which should reduce noise a bit and add a bit more luxury to the car.
The new seat has been done by PJM, another good job from them for a reasonable price. It has been waiting to go into the car for about 6 months now, but it shouldn't be long now. The holes for the runners are all in place, unfortunately there seems to be a missing centre runner which is a bit critical as it has the adjustment catch on it. We have a possible solution, but it would be nice to get it sorted right first time.
Tomorrow it is time for us to get the all important Bedford started - it has been sitting for several months without attention and it needs an MOT before the various events in the next few months. So we'll get it started tomorrow hopefully, and then we can work on getting a ticket for it. If that goes vaguely to plan I might get on to fitting the carpets in the Jupiter and the seat won't be far behind - at that point the car is almost ready to go after nearly 3 weeks of work!
