Ben,
First, a welcome from everybody on the JowettTalk and the various Jowett clubs. We will help you all we can to get your dream mobile and beautiful. There are a few things you need to think about and look at here and in the JowettGallery which I hope you register on soon.
Perhaps start a topic on here so we can converse.
You can either approach this as a project manager and decide what, how much and when to do things, or just be opportunist and do things when you get the opportunity. I certainly recommend the drive and enjoy strategy, although it may take longer to get what you want and you will not get a concours winner as the first things you restore will deteriorate. I have had that strategy for 43 years on my current Jup (enforced by lack of money in the early years)!
I hope you will ensure with Footman James under the club scheme with which you have breakdown assistance. You will probably need that if your first drive is 600 miles up country!
If the car ran before it was laid up, then hopefully we can start a list of things to definitely do, and follow that with a list of things to check in the inspection.
My starter.
Tyres quality and pressure, change brake fluid, test brakes, check brake pistons/seals, springs and shoes, adjust brakes, handbrake grease and operation.
Engine, gearbox and diff oil, oil filter, petrol drain and refil, petrol filter in pump and under chassis, petrol pump operation, carburettor bowl clean and float valve operation. Water flush and refill check leaks. check water in oil.
Check turns 720 degrees on starter handle. Make sure nothing is seized (e.g. valves that will push through pistons).
Compression test, valve operation, if no problems tappet adjust, otherwise heads off.
Electric short circuit test, new battery, check operation all electric circuits, check correct amps on ammeter for each circuit.
Check gearbox on starter motor with one (or two) rear wheel off ground. Clutch may be stuck and needs releasing.
Oil pressure on starter motor? Oil leaks? Fix if not.
Start engine, charging? Oil pressure? Any noises?
Run engine check all cylinders and tickover. Check operation of gearbox.
Run for 10 minutes, 75deg C?
Check steering with front wheels up. Check no fouling or clunks from lock to lock. Check track rod and steering balls.
Take for road run if poss. Even braking and noises?
Good to go!
