The first important job was to get the right recesses cut for the front of the hood latches, a quick bit of routing and chiselling and these were done. A few holes drilled, and they were solid. Which is nice, because otherwise the hood wouldn't stay closed properly at high speed. Which would be bad.
Keith was busy taking photos of things, clearly a bit fragile after a few drinks yesterday at the rugby
Final bit of shaping was to rout a rounded edge on the inside front of the vertical baton. This will avoid anyone catching their shoulder or anything else as they get into and out of the car, and also if there was a crash it is one less sharp edge to hit things on. It also looks pretty, and will avoid any damage to the edge of the wood, which might accumulate dirt otherwise.
Once this was done all the woodwork was ready to go. No more cutting and chiselling, just clean the pieces up and get the magic oil/varnish stuff that Chris had brought along onto them.
Sanding began in earnest, cleaning up all the sides of the 6 pieces, removing pencil marks, ironing out any imperfections in the surfaces. This took rather a long time, but soon enough we could mask off the surfaces that we will be applying sealant to for the door and windscreen seals and then Amy could get some of the magic treatment onto the wood.
Apparently we need to do about 4 coats of this stuff. So a few days of doing that before I can put everything back together.
While Amy was sanding, I did a bit of work on the steering wheel. The paint on the centre was a bit rough, and when trying to polish it up it was clear that it wasn't very thick either. No problem, a quick wipe and a few coats of black spraypaint and it was looking a lot better. Once it is completely dry I'll be able to give it a quick T-cut and put a bit of wax on it to protect it from all the hands running over it for years.
Next job while coats are drying on the hood frame is to sand the steering wheel, which will be treated with the same magic stuff so that the wood matches all the other wood in the car. Not so much pressure on the steering wheel, whereas the hood frame has to be fitted and ready for vinyl fitting next weekend, otherwise we won't have much time left before the rally. Two weekends to go now, and the SC needs an MOT and a working horn before then...
