A35 video
A35 video
For those viewers of You Tube there is a video entitled 'The Austin A35- making the most of it'. It only last about 12 minutes, but is the 1955 video of an RAC road test of an A35, taken straight off the Longbridge assembly line and given a road test of about 500 miles, to record it's petrol consumption.
Ok, but where is the Jowett interest, you may ask? Well, the video records a view through the windscreen of the A35 and is a triangular route through many UK towns, starting and finishing in London. The roads are mostly old 'A' roads, all before the construction of the motorways. As such, there are lots of shots of 1950's and pre-war cars, including at least two Javelins. There may be more that I have missed? It's also in colour, which must have been quite rare at the time?
The A35 completed the route successfully, and recorded a fuel consumption in the low 40's, which must have been pretty good?
A bit of Christmas viewing?
Re: A35 video
StevenGray
Given Name: Steven
Re: A35 video
Post by StevenGray »
A Bradford at 10min 25sec
Bradford Owner since 1971
Re: A35 video
There is more Christmas viewing in the Jowett- video library. Click on the Search Server button at the top of the page.
Over 100 videos available.
You do need to login to Member Services since we need to make sure you are a club member. If I get time I should be able to make this easier for you by doing a lot of programming by using your JT credentials. But for now you do need to Register and then login to Member Services. Note you can save the activation link as a Bookmark, Desktop icon to make life easier.
