The following list of primarily technical contents of the NZ Jowett Club magazine Flat Four was compiled by Bob Culver for his own purposes. All of his contributions are recorded, including trivial. Non tech inclusions do not follow very consistent pattern.
Layout is not ideal. It arises from conversion from Brother WP.
The list may prove useful to others. Simply reading it through will draw attention to key points. Branches and some members hold collections of old Flat Fours. (Bob Culver's contributions from FF 140 are held on storage and with some re formatting could be made available)
A searchable version is available. Otherwise users will just have to trawl through.
Note that FFs 1 to 29 were progressively reviewed commencing FF 146. Adequate information may be available from the review.
Unless there is some indication otherwise, topics and references generally apply to Javelins.
KEY
( ) contributed by other than Bob Culver
Underline selected important topic and/or comprehensive coverage
A t C- Around the Clubs, summary of overseas mags
A t C- ref..topic A t C. Reference to but no detail in FF
[ ] trivia
FF1 Nov 1962
(Road Test)- of Jav from NZ "Stag" of 1952
FF2 1963
(Mods to the Jow Jav)- list of factory changes
(Loss of Oil Pressure)- oil drain screw too short
FF3
(Excessive Steer Wheel Vibration)- worn rubber susp bushes
(The Jav and Jup)- brief hist and perform from a "Motor" book
FF4
(Lost Causes of Motoring)- from Montague book; hist to early 20s
(Excess Oil Consump With Rebuild)- ring lands excess dia
FF5
(The Old Grey Mare)- Wgtn-Auck by Jav. A.N. Palmer
(Lost Causes..)- hist mid 20s-mid 30s
(Sudden loss of Oil Press)- rear timing cover-crankcase gasket
(Repairing a Jav Steer Box)- fractured quadrant base
FF6 1964
(Jowett Factory Closes)- JEL at Howden Clough closed early 1964
(Lost Causes..)- mid 30s to early Jav
(Auckland CDs) - Jack Stiffes CD fours, one high comp
(Motor Cutting at Speed..)- short petrol pump pushrod
FF7
(Lost Causes..)- Javs, Jups, R4, Le Mans, gbox probs, to the end
(Bradford Utility)- "Motor" Tests 1952 of 6 light. Perform data
(Loss of Power)- ht screws not penetrating
FF8
(My First 15 Months of Jav Ownership)- cam wear. diff maladj. Fisk
(A Mysterious Knock)- loose crankhandle dog
(Fuel Econ Run)- Wgtn 1964
(And Thus It Came To Pass)- 1949 Spa 24 hour. Hume
FF9
(13 Years With Jav)- water in mani, cam & rocker float, synchro balls
(Interesting Mods)- oil coolers, effects, BMC followers, Vic's Jup
(J Jottings)- Jav "S" models with Jup mechs
(Snippets)- loose Panhard rod
(photos)- Stiffe's CD, Becquart with Farina Jup
FF10 1965
(NZs Finest Jav)- Wilson car Padman rebuilt
(Emergence of a Classic)- 1960s UK prices of Javs, Jups
(Jav Road Test)- Autocar 51
(J Jottings)- mention of the Wylie and another racer
FF11
(Grasshopper Jowett)- NZ 1930s exper with very early car
detailed mech desrip of. Buxton
(J Jottings, Mail)- mention Vics racing, Minor with Jav engine
FF12
(Salute the Jupiter)- 1950 Motor Sport test
(Engine/Road Speed Conv)- Jav Jup models
FF13
(Modifying VW Oil Cooler)- with dwgs. Fisk
(Maintenance Tips)- rebound buffers, horn ins, column removal
(The Jaguar Eater)- Vic Morrison Jup racing
(Bradford Service notes)- internal oil leaks, CC rear oil seal
oil press valve, oil leaks at distr
FF14
(Fuel Econ trials)- results of 1964 Club run, and other comps
(Comparison of Two 1½ Litres, Decade Apart) Jav and 63 Cortina
(photos) glossy, of members CD, 10, Jav, Jup etc
(Mail) incl Youren on his Jup
FF15 1966
(Fuel Econ trial)- 1965 Wgtn
(Trade topics)- Padman susp parts, lube free kp bushes etc
(J Jottings)- Jups imported 2nd hand
FF16
(John Bolster Tests Jup)- "Autosport" Jan 52
(Deciphering Engine Numbers)- systems used from earliest
(Fitting Oil Cooler to Jav)- cooler, and adaptor suit early filter
(Milestones)- sketch and details 1906 proto
FF17
(New Jav Engine)- perform comp proto Padman with Jav, Jup, VW1600
(Book Review)- Classic Car Profiles Jav, Jup
(J Jottings)- Wylie Jav comp news
(Mail)- L Davison Jav mpg on tour
(Confidence)- 1924 catalogue info re 6000 mile trial in Africa
(Milestones)- sketch and details 1916
FF18
(Report on visit to Aus)- mods seen, incl liner O rings. McKee
(BP Test Bench)- 8 Javs and a Brad tested in Wgtn
(Milestones)- sketch and data 1924
FF19
(The Jav and Jup FF Engines Pt 1)- technical development of. JCL
(10hp Jowett Saloon De Luxe)- 1935 Jason road test
(Crankcase Breather Valve)- operation and detail
FF20 1967
(The Jav and Jup FF Engines Pt 2)-
FF21
(BP Test Bench)-
(Javelin Road Tested)- prototype by "Motor" May 47
FF22
(Six Cyl Performance From a Jav)- Padman perform cf 1967 contemps
FF23
(Gearbox Face Gasket)- and other gbox leaks. Collins
(BP Auto Test Bench)- Javs and a Brad in Auck
FF24 1968
(Padman Engines Tested On Dyno)- cf Fiat 1500 and Hunter
(Gearbox Bell Housing Joint)- sealing, breathing. Perrot
(The Javelin Road Tested)- "The Motor" May 1947 prototype
FF25
(Jowett Jupiter)- "Road and Track" 1953, objective test
FF26
(The Wylie Javelin)- Australian racing special. Polain
FF27 1969
(Carburettor Icing)-
(Have You Checked?)- hydr lines, Panhard rod, Jup chassis
(Branch News)- Econ Run Chch, Jav 45 mpg
FF28 1971
(Zenith Carbs)- detail workings
(Notes From Garage mechanic)- wheel studs turning, stones in cyls
(Branch Notes)- 1970 Econ Run Wgtn
FF29
(Javelin Engine Mounts)- alternative. N Moore
FF30
(Notes From the Garage Man)- head stud leaks. steering lock. Moore.
(Javelin Tuning Notes)- 1952 JCL advice, with N Moore comments
FF31
(Notes From the Garage Man)- shaft pstns for alt distrs. tight gbox
(Radial Tyres)- on Javs. MacKenzie
(The Morrison Jowett Story Pt 1)- Vic Morrison
FF32 1972
(Milestones)- Jowett development to 1926. JCL
(The Morrison Jowett Story Pt 2)-
FF33
(Milestones)- 1926 Africa crossing
(Whats Your Problem?)- piston fit. timing cover gasket. fuel pump
(Crankcase Breather Valve)- descrip, no diag.
(The Morrison Jowett Story Pt 3)-
FF34 non exist? numbering error?
FF35
(Across Africa By Car In 60 Days)- 1926 Jowett venture
(Notes From The Garage Man)- Bradford valve overhaul
Jav water circ mod. oil consump. Jav/Jup bhp
(Days with Jowett)- Siree reminiscences
(The Morrison Jowett Story Pt 4)-
(Step Out Alive)- seat belts, smashed Jav photo
Cylinder Head Drain Taps- a secure alternative
Rebound Buffers- a crude substitute
FF36
(The Morrison Jowett Story Pt 5)-
How Do Javelins Compare?- an objective appraisal
Understeer, Oversteer, and Javelins-
FF37 1973
(The Morrison Jowett Story Pt 6)-
The Mysterious Balance Pipe- function, faults
Water, Water Everywhere- leaks via head studs
A Teaser- questions toe settings
Rock A Bye Engine- torque reaction buffers
Stopping Longer- PC-PE rear shoe mod
FF38
(The Morrison Jowett Story Pt 7)-
FF39
(Differences In R4 Engine)-
(Gbox Mods, Needle Rollers, 3 Thick Thrusts)- (some dubious advice
re gear mods. ref FF73)
(An Epic Journey..)- retrieval of two CDs from Auck to Wgtn,
one A framed by Jup. Bergin and Wickens
(Days At Jowett)- Siree
Safe Jowetting- long original article on all aspects of mechanical (dubious advice re hard chroming ref FF45, 140)
83 Or 93?- octane ratings
FF40 1974
(Some Hints On Rust Damage Repairs)- basics. Lesley
(Conversion of Front Hub)- roller bearings. McKee
FF41
Curing Cracked Crankcases- crack adjacent rear water inlet
Gearbox Thrust Washers Again- (dubious advice re alternatives ref FF45,47, 140)
Toe Out- d.i.y procedure
(To Be or Not to Be)- dirt and ruined crankshaft
FF42 1975
(The CD Bradford)- rebuild. Bergin
On Economy- in general, and for Javs
Water Injection-
Transistor Ignition-
Prolonging Life- of Javs, by sympathetic driving
FF43
(From a Jowett Employee)- Harry Gill
(Fuel Pump Primer)- manual. Hingston
FF44
(Jowett History)- summary. Bergin
(Layrub Couplings)- and centre bearing. Furness
(Bradford Steering Damper)- hydraulic, from "Jowetteer"
Better Than A Bought One- addnl crankshaft counter weight
(incl calc errors ref FF119, 121)
(Ten Cent Reconditioned Mainshaft)- poor advice, ignore, ref FF72
(From National Secretary)- early cars in NZ.Wise
FF45 1976
(Jowett History)- brief Jav, Bergin
(Javelin Cylinder Heads)- anti-inserts, alternative. Wickens
As You Were- gearbox thrust washers, hard chroming
FF46
(My Jowett Story)- Wally Fletcher
(Exhaust Supports)- ex BMC 1100. Hingston
Keeping Fit and Wealthy- d-i-y tyre changing
Thoughts On Roll- anti roll bars
FF47
(The Winder Bradford Story)- David and Anne
(Yet Another Jowett Employee)- about Hawthorne
(Why It Wouldn't...)- mixed timing marks, reverse starter. Morrison
Troubled Heads- head cracks, seat wear, d-i-y cutter, inserts
The Last Word- gearbox thrust washers
FF48 1977
(Mr Wise's Vintage)- recollections of a Jowett in NZ
(Jowett Employee's Notes)- Harry Gill
FF49
(Radials Or Cross Plies On Javelin- rim mods. Furness
Fan Bearings- of white metal
The Dinkum Oil- oil consumption
FF50
(More Jowett History)- CD, R4 photos
Another Jowett Story- Bob Culver's
A Querry On Crankshafts- nitrided journals, ever hard?
FF51 1978
(Full Circle Pt 1)- Jowetts forsaken, Vic Morrison
(Away North, Away South)- A framing stacked Jupiters. V Morrison
(Treatise On Engine Bearings Pt 1)- general practise. N Moore
(Taper Roller Wheel Bearings)- Jav conversion. McKee
(Another Priming Device)- parallel electric pump
(Gearbox Oil Leaks)- vacuum cure.
(Bradford Headlights)- adapting reflectors. Winder
FF52
(Engine Bearings Pt 2)- case mod, semi groove mod of Perkins brgs
(Full Circle)- return to Jowett fold. Morrison
FF53 1979
(Fifteen Years Ago)- memories of JCL, JEL closure from "Jowetteer"
FF53A
(Modification to Water Circ)- JCL recommendation
(In Search Of Longer Legs)- twin gearbox. Morrison
(Tips On Gearbox Replacement)- N Moore
(Radiators, Water Pumps and Fans)- circ filter, elec fan
FF54 1980
(The Story of R1 438)- speedboat "Pacific Spot". N Moore
FF55
(Jupiter Given new Heart)- rebuild. Bolter
(Plastic Jupiters)- fibreglass bodies. Winder
FF56 1981 not seen
FF57
(Reg Korner Meets Jupiters 26 Years On)- Nankivell
FF58 1982
(JCL Jav advert)- "Used To Be A Long Journey"
(Fuel Economy Implications)- Brit author Gordon Wilkin's Jav exp
FF59
(Javelin and Jupiter Development)- Grandfield of JCL on Jav eng,
incl competition dvlpmt (as FF19,20)
Javelin Now Really a Bomb- CNG, installation and run costs
Belt and Braces- oil warn light for Jav
FF60
(JCL Jav advert)- "She's A Lady"
(Cooling, Petrol Saving). rad clean flush, carb jet changes
(Alternatve Transport Fuels)- extensive, incl methanol etc
Pinking Javelins- due oil burning
Rusting Javelins- door window weatherstrips
Around the Clubs- first article of series
FF61
(West Riding Work Horse)- Bradfords, from "Truck" mag
(Hints For The Mechanic)- pushrod lock plate
Spot On- timing procedure
Squeaking Javs- torsion bar anchors
Those Old Advertisements Are Irresistable- a send up
FF62
(Photo..vintage 4 seater)-
(Jowett Competition Successes)- postwar
(Head Problems)- anti-inserts
Ridge Removal- from liners, d-i-y
[Sideways Javelins]-
FF63 1983
(JCL Jav advert)- "Easy With The Throttle"
Wandering Javelins- d-i-y align, incl ball joint height
(castor advice wrong)
Camber Pull- explanation
A t C- loose rollers for gbox
FF64
Guilding the Lily- aesthetic painted rims
Bearing Up- white metal cam bearings
A t C- drag co-effs, Jav and others
FF65
Royal Company- other crankshaft breakers
Cut Thrusts- Cu-Pb subst crank thrusts
A t C- two camshaft types for pre-war twin
different clearances for timing and for running
FF66
(By Jupiter)- lengthy, from Australian Sports Car World Quarterly
De Clutch- treatment of and life etc, faults, adj
FF67
(Head Aches)- excessive liner standout
Hard Case- used crankshaft selection, re-nitriding
Good Medicine- introduction of 91 Octane Regular
Learning the Hard Way- cyl head torquing
FF68
(Letter..re Fitting Inserts)- in defence of inserts. Henderson
Cracking Up- clutch pilot bearing
Clutching Fingers- d-i-y adj of
Twisted Design?- torsion bars
A t C- nitrided camshafts
FF69 1984
(Driving Hints)- early vintage, incl double declutch
A Dilemna- to publicise faults?
Springtime- valvesprings, ident of, pressures, Manual clarified
On Drop Outs- anti inserts, alternative valves
FF70
(Photo..1926 sports racer)-
(The Wylie Javelin contd)-
Look to Your Arms- cracked steering arms
Do Not As Others- care of front hub ring
Skyhooks- chain hoist instead of jack
A Plea- preservation of 2nd hand parts in useable order
FF71
(Photo..1915 model)-
(The Jowett Twins)- to 1940, from "Collector's Car"
(Jowetts Steer Toward Recognition)- from Aussie newspaper?
True Confessions- of the Furness Jav
Safety Pins- kingpin failure, recond, defects of hard chroming
Freshwater Seals- O ring mod for liners
FF72
(Throwing The Javelin)- about Jupiters, from a classic mag
(Taupo Or Bust Via CDR3)- overheating due porous liners. Morrison
Silk Purse From Sow's Ear- non calamitous gearbox faults
A t C- in situ valve spring replacement
FF73
Things That Go Bang In The Night- serious gbox faults, and counters
[Caption Competition]- entries
FF74
(Photo..Farina bodied Jup coupe)-
(Requirments for Correct Torquing of Threads)- tables for high tens
(Raising the Bradford CR)- ingenious machining. Emms
(Notes on Bradford Crankshafts)- pre-tension bolts. Bolter
Bradford Crankshafts- comment on above
A t C- Bastow on R4 performance (not R1 as text)
FF75 1985
(Photos..1928 large saloon, and 1935 Jason)-
(1950 Cars; Jowett)- new ERA Jav, with photo, from "The Motor"
How the Jav Compared- performance Jav/Jup cf 27 contemps
Bad Backs and Wishful Thinking- weights of Jav parts
Why A Jav?- reasons for owning
A t C- vintage oil consump, Dr Smallhorn and his Alpine Jav
FF76
(Reconditioning the CC Bradford Steering Box)- Emms
Heath Robinson Revisited- additional brace for water pump
Hotting the Oldies- aspects of raised CR
Further Musings- rear hub seals
FF77
King Canute- O ring seal for crankcase tie bolts
A Case Study- long term wear of engine of Culver's Jav, ideas
(Flat Twin No 1)- 14mm plugs, 2.5v ignition warning light circuit
photo WD engine
FF78
(Reconditioning the CC Bradford Steering Box Pt 3) Emms
Sounding Off- "old car" magazines and old cars
Piston Broke- defects with original pattern pistons
(Flat Twin No 2)- fitting temperature gauge
FF79
(Photos..1935 standard saloon. R1)-
(By Jupiter)- Farina coupes, from "Classic and Sportscar"
(Reconditioning the CC Bradford Steering Box Pt 4)- Emms
Jowett Kelvinator- carb icing
(Flat Twin No 3)- photo of stripped 1926 Sports
battery cable fire risk, fitting solenoid
FF80
(Photo..1935 2 str dhc)-
(Balancing Bradford Wheels)- d-i-y. Emms
Humble Pie- use of O rings, incl rear timing cover, Viton
Sensing Direction- modern indicators
(Flat Twin No 4)- Tech specs J 1936, 7J 37, 8J 38, SG 35, 6G 36
7G 37,38, van 1946. Wiring diags 36 four, twin
with 3 stage charging
FF81 1986
(Photo..1930 Long 4 seater)-
(Places Where Jowetts Were Mentioned)- magazines 1959 to 1985
(More On The Bradford Steering System)- Emms
Plumbumming- spirit lamps, solder repairs
Sleeping Javelins- sleeper conversion
Fit and Forget- front wheel brgs
Hot and Healthy- cyl wear
Drippy Design- oil leak, timing cover setscrew
On Balance- d-i-y static wheel balance, hubs
A t C- rubber presses, as used for Jup production
(Flat Twin No 5)- ref to the Jowett Owners Mtce Handbook 1935-39
FF82
(Modifications to Jup Steering Box)- to minimise rattle. Bolter
(1986 Le Mans Relay-Pukekohe)- Moore
Computer Diagnostics, Who Needs This?- uses of crank handle
Gearbox Oil- reuse of
A t C- secure ring gear attachment. Jup oil consump
(Flat Twin No 6)- SGI replacement cranks
FF83
(Supporting Bradford Front Mudguards)- Emms
(Jowett Genius)- reprint from "Mayfair"
Ringtime- re-use of piston rings
A t C- 1952 prices Jav/Jup
(Flat Twin No 7)- heater for Bradford
FF84
(Photo..1933 Kestrel)-
(Two Jowetts Go Racing)- Vic, Les, photos
(A Bit About Kingpins)- Bradfords. Emms
A Jack Up- alternative jacking
Time Savers- valve adj, susp oil reservs, hub removal
Rivet On Brake Linings-
(Flat Twin No
FF85
(Improving Bradford Headlights)- relays. Emms
(Instruction For Fitting Steel and Rubber Shackles)-
Putting Cork In It- d-i-y sump gaskets
Going Around In Squares- centrifugal force, stopping distance etc
(Flat Twin No 9)- new axles, mazac replating, sketch Jupiter 10/4
FF86
(Photo..CD saloon)-
(Handy Hints No 1- ball jt remover, a chain gripper
(Taper Tale With A Difference)- hub tapers. Emms
(Private Entry)- Jav in 1951 Alpine, from "Autocar"
Thirty Five Years Ago- Jav/Jup new prices and 32 others
Placating the Neighbours- transport of dead Javs
Backstops For The Backstoppers- rear shoes, improved, correct, fit
A Rolls Jav For S/15- earmuffs for silence
A t C- battery rejuv additive
FF87 1987
(Oil Leaking Bradfords. CC Models)- Emms
(Handy Hints No 2)- rad hose remover
Improving On Nature- aesthetic rear no plate mount
Clutching At Life- typical clutch use and life
A t C- bhp stock and mod Javs/Jups
(Flat Twin No 10)- How to Recognise a Rotten Day for Jav Owners!
FF88
(Photo..R4 Jup)-
(Roy Lunn Writes)- about his JCL and subsequent career
(Economy And Bradfords)- Emms
A Lead To Lead Free- use of unleaded petrol
A t C- Victoria Worsley, vintage Jowett competitor
(Flat Twin No 11)- focussing Brad lights
FF89
(Photos..CD ute, 1930 fabric)-
(Bradfords and Wheel Shimmy)- Emms
Weighty Matters- alternative economy run formulae
How To Lose Weight For Improved Performance- possible savings
A t C- J type gboxes. Vintage sports model acheivments
(Flat Twin No 12)- generator overhaul, fitting 4 speed box. Vic
last of series about Myra, a UK trials special
FF90
(Benchmarque)- McAuley on Javs in "Classic Car"
(Handy Hints No 5)-
(Castor Angle)- Bradfords. Emms
(Singles and Twins)- Cooper Bradford!
An Extravagance About Economy of Petrol- theory & applic
A t C- Weslake and heads. proto Jav. TT Jup speeds. mod Jup bhp
(Flat Twin 13)- Montague on Jowett History. Voltage regs
VM carbs, progression jet mod
FF91
(Photo..1920s light 4 seater)-
Economy Pt 2- driving technique
(Flat Twin No 14)- Montague contd. Voltage regs. Emms
NZ Jup racing, SU elec pumps
FF92
(Photo..1911 model)-
(Four Speed Bradford)- Jav gbox conv. Morrison
(CC Bradford Ring Gear)- Emms
(Handy Hints)-
100,000 Miles By Javelin- mechanical history of Culver Jav
A t C- windscreen rubber fitting tip
FF93 1988
(Photo..R4 coupe)-
(Member Profile..Wally Fletcher)-
(Handy Hints)-
(Trials Bradford Specials)- from 1951 "Motor Sport"
Rock and Roll- roll, handling, over/understeer, s.a. influence
(incl error sa bush angle, 60-55ø, ref FF101)
A t C- 1951 Australian new car prices
FF94
Never Too Old To Learn- rain leak into ram tube
More On MPG- simple check technique
When Cold Can Mean Hot- temp guage deception
No Plastic Bag Wanted- newspaper for general cleaning
CNG Reconsidered- merits
FF95
(Member Profile..Wally Fletcher Pt 2)-
(Handy Hints)-
A t C- susp hardening depth. list of Jav/Jup roadtests
early Jowett history
The Way Things Were- vehicle life in past
Speed Oh!- d-i-y calibration check
CNG Continued- mixers
Going Grey Over Not Going Grey- exhaust colour
FF96
(Member Profile..Wally Fletcher Pt 3)-
(Bradford Brakes)- Emms
On Cranks, For Cranks- catalogue crankshaft types
A t C- early Jowett history. drilled crankpin Jav cranks
CNG Postscript- wear aspects
Stopping Longer- rear brakes, correct assembly
FF97
(Oil Hazards)- skin exposure
(Treatment for Soldering Cast Iron)- flux
(Repairing Worn Carb Spindles)- Emms
(Handy Hints)-
Distributing Life- distributor wear, spring part nos
Guarding Your Ass- low level reflectors
Plus the Series 3- another Jav crank?
Hard Ones and Soft Ones - crankshaft hardness and wear
Those Bleeding Brakes- d-i-y bleeding
Up Your Beam- headlight adj
A t C- early Jowett hist, vintage perform. rad clean
FF98
(JCL vintage adv)- "Solidity"
(Smooth Reading Speedos)- cables
Technical Rumblings- front wheel bearings
Lighting the Way- headlight bulbs
Dirty Thoughts- oil filter life, by-pass pressure
FF99 1989
(Static Timing)- d-i-y using lamp
(Smooth Pipe Bending)- petrol pipes
(Fuel Pump News)- AC pumps
(Joining Metal By Solderin )-
(Torque Sense)- elec indicator for torq wrench
(Hot Tips In Plug Selection)- plug princs. torque. no type recmds
From The Archives- repl for cyl head drain taps
Telling It Like It Is (Or Was)- Jav appraisal relative contemps
A Bumpy Comeback- crude subst for rebound buffer
FF100
(Vacuum Gauge)- for testing Bradford crankcase
All That Glitters Is Not Chromium- imitation number plate surround
Say Man, Do You Know How Cool You Are?- capillary repair
Curious Knocks- PA-PD susp end float, rocker arm float
Variations On A Theme- humour, old JCL slogans
A t C- Octanes 1950s Britain, JCL hist. vintage oil consump
List of mag refs Jav/Jup. McAuley Jav mods
FF101
(Tape Trick)- making new brake pipes
(Bleeding Brakes Single Handed)- utilising a tyre valve
(Pirelli Classic Marathon-Europe)- McAuley
(What You Wanted To Know About Ball Joints)- tightening taper type
A Bore On Wear- ring and cyl wear
A Nerror- correct angle for fitting PA-PD sa bush
A t C- the Yoeman
FF102
(JCL Jav adv)- "Shes a Lady"
(Letter)- from a NZ Jowett assembler
(Get Your Bearings)- basic procedures rolling bearings
(Compression Tester)- from a tyre gauge
200,000 Mile Tune-Up- mechanical history, Culver Jav
Lucky Lips- cyl wear lip
Bushed- fitting PA-PD sa bushes
A t C- assy advice, Polain of Wylie Jav
FF103
(Soft Jaws)- vice jaws for tubes, rods
(That Car Was A Steal)- Motor Vehicles Security Act
(Three of a Kind)- Jav/Jup comparison. McAuley
(Safe Way to Start a Car)- jumper leads
Safety is Not Just a State Of Mind- sedate road tests old cars
A Stitch In Time- worn commutators
Heart Rending- preservation of used liners
Bear With Me- engine bearing materials
A t C- petrol tank repair cautions. 1952 JCL Jav/Jup tests
FF104
(When a Woman Buys a Car)- "The Motor" 1935
(Inflation Pressure Related to Tyre Performance)- standard stuff
TD Or Before TD?- static timing, octane, distr wear
A t C- temp sensors, dowelled crankcase, rad cleaner, nuetr.
FF105 1990
(JCL Jav adv)- "Used to be a Long Journey"
(Timing Light)- strobe type
(Studs)- removal etc
(Battery Care)- basics
A t C- DM2 distr dynamic adv.
The Dull Life- radiator inhibitors
Old Fingers- wear of clutch fingers
Food For Thought- alternative tyre musings
More Food, Less Tyresome- alternative con-rods
Show Me The Way To Go Home- car compasses
FF106
(Brake Service Hose Clamp)- as used by garages, but dubious
A t C- valve breakage
A Matter of Moment- streamlining and Cd, examples
In The Black Or In The Clear- oil discolouration
FF107
(Terminal Tip)- non solder battery terms
(Batteries)- basics
Whoopee!- piston speed, with examples
Does Your Baby Rattle?- gudgeon clearances
Is Your Jav On Its Bones At The Arse?- rear t.b. rubbers
FF108
(Liner Puller)- made from a jack
(Plug Polarity)-
(Technical Notes Concerning Jup)- comp tyres, rims. distr. Clements
What Is Best For Your Nipples?- chassis greasing
Plugging On- original plug covers
Flashback- more on Cd incl MGs, piston speeds. rear tors bars
A t C- Tech Info Leaflet on Gboxes. "Jowett Sport 1989"
FF109
(Jacks)- basic use of
(Keeping Your Cool Under Pressure)- cooling basics
Take A Breather- correct op of crankcase breather
A t C- lead and seat wear. vintage driving practise
Korner and Jup develop. Jav gear steel. PBR hyd-mech parts
FF110
(Understanding Compression Rings)- descr of types
A t C- Forsheda face oil seal. pre-war gbox leaks. 72hr record
rear t.b. replace, subst Triumph starter pinions
Regularity and Longevity- greasing and greases
FF111 1991
(Photo..1930s Jason or Jupiter "streamlined" saloon)-
(Vehicle Standards)- new regulationss re mods. Emms
(More On Rings)- reconditioned grooves. Emms
A t C- water pump repair. rocker cover noise. model Jup
All Steamed Up- pressure caps, probs if not working
Telling the Old Old Story- assy to avoid bearing troubles
FF112
A t C- replace of Jup steer pinion and tors bar bushes
A Conservationists Dream- resource conservation and old cars
FF113
A t C- postwar Rover, Jag, Riley, Wolsley, Jav comparison
Rotating The Turners- rotation of tyres
FF114
(Photo..Bradford in the Dolomites..1949)-
(My Racing Classic and I)- Neil Moore, from "NZ Classic Car"
(Rust Never Sleeps)- rust counter measures. Emms
(Tip Of The Javelin)- brief story of the Jav from "Wheels"
A t C- loose steering boxes. engine oilways. The "La Roche"
Is Bump Steer Giving You A Bum Steer?- ball joint height adj
FF115
(My Classic and I)- Brewery Bradford from "NZ Classic Car"
A t C- Jup across Nth Africa
Keep On Rolling On- driving technique for oldies
FF116 1992
(Photos..1932 lwb tourer, 1931 mech horse)-
(Born Again Boxers)- Ray Win and Jowetts
Road and Track- racetrack cornering methods
The Bad News and the Good News- roll and cornering
Riding On!- driving technique, esp on shingle
A t C- Chrysler report
FF117
(Conversation With Andrew Madeyski)- engineer with JCL
(A Matter of Direction)- Jav starters. Emms
A Balanced Look at Unbalance- balance in perspective, typical tols
A t C- Chrysler report, anneal aluminium
FF118
(More on Starters)- overhaul incl pinion. Emms
Happy, Sad ..Tappets- valve adj, failure, seat wear
Putting a Good Face On Your Seat- seat width and life
A t C- Jup prices rel wages
FF119
(The Last Word On Starter Motors)- pinion removal. Emms
Putting Your Weights Up crank forces and extra counterweights
crank configurations
A t C- Jup speed hood up/down, halogen bulb conv
FF120
(Photo..special bodied Jav)- fibreglass 60s amateur coupe
(Wellington Bradfords in the 40s-50s)- a users experiences
Breathing Easy- alternative larger carbs
A t C- ref to Jav to Jup steer col mod
FF121
(To Breathe Or Not to Breathe)- Jav diff breather. Emms
[Momentous Milestone..]- George identifies Jav
More Counting On Weights- "worth" of extra counterweights
A Starting Point- observations on old starters
A t C- pre war motoring. Jav endurance runs. "Jowettsport 92"
NZ ckd nos. Leavens on Rallying. Polain on Jav engine mods
FF122 1993
(Pirelli Mainland Classic Tour)- Emms
Interruption Of An Era- demise of Culver Jav
Bearing Up- bearing life, Culver Jav
A t C- R1 details
FF123
(The Javelin Horn)- insulator failure on column. Emms
An Old Convenience- gallons
An Illuminating Tip- plastic lens rejuv.
Winding Back The Clock- 1950s roads and driving
A t C- Korner obituary. vintage oil consump
FF124
(Roy Lunn)- letter and photos of twin CD test in Europe
(Reg Korner)- obituary, incl recent photo with pre war 8hp
(A Bit On Layrubs Couplings)- bush replacement. Emms
More 1950s Memories- roads, driving, cars, period quirks
A t C- Jup cooling probs, ref to airflow guides
ref to Dellorto carbs in Jup
FF125
(Member Profile.. Albert Williams)-
(Changes to Transport Legislation)- vehicle licensing
(Amends to the Transport Registration Act)- vehicle licensing
[Another Javelin Problem]- excess spares
A Celebration- bolt torque. bore finish. rings assy
A t C- 1950s trials car. alternative Mitsu Jav pistons
Jason purchase. 2nd hand prices prewar cf wages
FF126
(Member Profile.. Irving Harrison)-
(Bradford Front Axle Stabiliser)- transverse link. Pegg
More Light On The 1950s- 1950s vehicle lighting
Seven Inchers, The Ideal- 7" headlamps
A t C- 1st of John Baldwin. Leavens. basic cooling defect
cam followers 10 deg, Jav numbering. ref to Bendix brake data
FF127
(Member Profile..Jonathan and Karen Heap)-
(CD2)- CDs generally, CD2 now CDR3. Morrison/Green
(Jowett Ideal For Vintage/Classic Racing)- Vic's CD3, "The Press"
Balancing- report on visit to specialists
A Tilt At Balance- engine "balance" generally, sane tolerances
(ref also FF44, 85, 107, 117, 119, 121)
A t C- Baldwin. rejuv small headlamps
Jav perf cf 5 contemps. Jup air baffles. ref to CB jets
FF128 1994
(Member Profile.. Brian and Melva Tattersfield)-
The Adventures of Harry- Ricardo, detonation, Octane
Running Boards and Thermette Smoke- period picnics
[More Inspiration]- A7s
A t C- Viton dangers. Baldwin
cooling aspects. Industry standard timing clearance
FF129
(Member Profile.. Gerald Batchelor)-
Separating Neighbours- valve port separation
A t C- crankcase top leaks. ref to carb diags. Baldwin
FF130
(Member Profile.. Bill Prosser)-
A Passing Thought- about Jack Stiffe
Travel Tyred- cross plies and radials
A t C- vehicle layup. JCL Jup report, speed reduc hood down
FF131
(Member Profile.. David and Anne Winder)-
Timorous Comment- satisfact fitting of eng brgs, tolerances
RON, MON, and Ricardo- Octane ratings
FF132
(Photo.. 1920s saloon)-
(Member Profile.. Mort Cruickshank)-
(National Radiators Visit)- rad manufacture, and care
In Good Company- mech woes Roycroft racers, Lycoming. crack detect
A t C- Gordon Wilkins. d-i-y trim clips. refs to windscreen work
FF133
Viva La Difference- merits of flat twin
A t C- Baldwin. Caudo Jup. list of Aussie mech mods
FF134 1995
(Member Profile.. Kevin and Trish Fowler)- reprinted in FF135
Too Clever By Half- unlubricated oil seal
[Memorable Journey]- loose exhaust baffles
A t C- JCL war hist. Yeoman. ref to Mc Cahill Jup test. Baldwin
FF135
Safe Jowetting 1- preamble, mech failures. steer/susp wear
A t C- crank oilway drilling options, bearing loads
FF136
(Member Profile.. Murray and Gwenda Short)-
Safe Jowetting 2- shock abs, drive failure, smooth tyres
A t C- Baldwin, Jav prices. car lay-up. plug and cover
recommendations
FF137
(Head Gaskets Jav/Jup)- torque, standout, nut seal
(Liner Shims)- solid, fitting of
Safe Jowetting; Weak Brakes- brakes, and problems, stuck pistons
A t C- Polain mods. Deroy. CD tests. filter ele. oil consump
heavy valve retainers. crank drillings. repl sa. "on fire"
FF138
Good Pulling- towing dead cars
A t C- Jav/Jup cooling syst quirks, part nos Jup air baffles,
meehanite Jav crank, brake lining material
FF139
(Member Profile.. Paul and Shirley Marks)-
Unleaded Petrol and Valve Seat Wear- experience Culver Jav
Ricardo, Octane Rating etc- applied to aircraft engines
Engine Bearings- tolerances again
Galloping Consumption- of oil compared ships aircraft
Unconnected Comment- Jav Econ Run mpg
[One Great Step...]-
A t C- 2 brg crank oil feeds, Jason rebld
ref to prewar commerc adv: replacement s.a. types for Jav/Jup
FF140 1996
A Gas About Steel- hydrogen embrittlement
Getting Plated- hard chrome plating
A t C- stiffened water pump support, ref dwgs gbox bearing puller
water pump disassembly. Tech differences Bradford models
1925 Egypt desert trip. Engr Maydeski
FF141
Valves, Lead etc Again- life of old valves incl effect of c.r.
Safe Jowetting; Tyre Blowout- tyre defects
A t C- perform table Jav contemps. 2nd 1925 Egypt desert trip
FF142
Is Your Knocker Worn?- camshaft wear
A t C- Model T production
FF143
Keeping Your Cool- cooling problems
A t C- ref..alt fwbs
FF144
(Member Profile..Barry & Sally Thomas)-
(Hugely Hilarious Joke..)- Jup gbox removal. Bolter
A Miracle, and Unasked Questions..- desaxe engines, offset pistons
Classic Cars and Mod Fuels..Shell- unleaded etc
A t C- alternative fwbs
FF145
Box Tips From Oz- selector problems
The Way Things Were- equiv pre-war prices, list of makes 1922
A t C- a Brit 1953 Econ Run, vol eff in cold air
FF146 1997
(Photo.. Jav proto mock up 1945)-
(Chch Happenings)- 1996 Economy Run
(From the President)- Neil Moore's worldwide observs
The Way Things Were- prewar basic running, equiv 1930s,50s prices
A t C- Laystalls nitriding detail, Culver case hist
FF1- Jav & Ngauranga climb
FF147
(Pirelli 96 NZ)- Cruickshnk
(Jowett Company)- rief history..Martin Howman
In Comparison- Jav cf Super Minx
Safe Jowetting ; Headlight Failure-
A t C- exh flange seal ring, Jav in Redex, Palmer on Jav
FF 2- no oil press due filter drain, Q car, 1959 Bradford review
FF148
Instant Horn- accessible horn button
Safe Jowetting; Windscreen Breakage-
FF 3,4- prices 2nd hand Javs, stuck piston lands, vintage prices
FF149
(Unleaded Petrol)- tech props cf prev, RON/MON. N Moore
(Jump Starting)- Bolter
A t C- obsc gbox roller substs, rubber bush part nos
exh system design, USA 1950s Jups exper, Gomm Jups
bhp Clements car, o/s Ford main shells, Fuelstar additive
FF150
(Photo..1927 7 saloon, Cookes saloon Jup)-
(Javelin Had a Point)- appraisal etc "The Daily Telegraph"
(Bradford Steering)- and flattened springs. Howman
Safe Jowetting; Brake Failur e- and A7 & Toyota anecdote
A t C- cracked quadrant, Becquart obit, fuel con additives
Redex Trials, Australia vehicle sales 1950
Jav u.j. alternatives, cast Urethane inserts
FF151
(NZ Fuel Specs)- composition, octane, RON/MON incl hist, storage
(Blank Paper & Mission)- Daily Telegraph interview of Palmer
(Our Bradford)- Elaine Proffit
Bear Baiting- Critique of WoF Guide on rust
A t C- ERA involvement, Robinson obit
dyn perf data, ohc heads, Avenger b.e. shells
FF 5- WN-AK trip, broke quadrant, burst gasket filter base
1920s prices, 30s techn develop
FF152 1998
(Photo..1930 van)- Ray Win's
(All Brit Car rally of NZ)- Oct 97
(Marcel Becquart)-
(Chch Branch)- 1997 Economy run results
Tirade Part 2- Critique of WoF Guide on rust contd
A t C- water pump support, pump dimensions
Shell Economy competitions, Wylie dies, Becquart, Robinson
a Javelin case history, [Hokitika reminiscences]
FF153
(Spark Plugs & Unleaded Fuels)- higher voltage reqd
Fallen Fuelstar- AA test of, a UK recom for valves & seats
Sound Familiar?- Cosworths & water pumps
Kiwi Ingenuity- scrap motor findings
Never Say Die- preservation of old parts
[More Whingeing- mechanic manslaughter charge]
[Memento- Toyota WoF]
A t C- oversize main shells, radials experiences, power brakes
FF 6- "Lost Causes" Jason-PA Jav, Stiffe's CDs incl water inj
FF154
(Detonation & Engine Damage)- ex MTA
Fuelstar Fights Back- new seats & lead, Avgas
Improving the Breed- car devlpmt, modern racing irrelavent
A t C- radials incl early, power brakes, 1926 in Egypt
FF7- Jup cf Porsche, 1952 Bradford test incl brakes
"Lost Causes": last Javs incl synchro cone seizures
F155
(Photo..Jowett 10)- at Hawera Rally
(Piping Hot)- repairing heater matrix
(Meet Executive)- Howman, Spragg, Bradford, McKee, Brownlie
Furness, Tomlinson
King of Tools- lathes
More Stirring- paint stirrers
A t C- rocker stud & oil feed variants, Honda uj for Jup steer
new camshafts, oil seal part nos, [Happy Chappy]
FF156
(Photos..SI Jups racing)- Ruapuna
(A Working Javelin)- V Morrison
(Speed day at Ruapuna)- L Gourdie
(Unleaded Petrol in NZ)- subst additives. N Moore
Safe Jowetting; Wheel/Suspension Failure- studs, kingpins
A t C- Australian Rally & long distances
outer rear hub seal renovation [Aside..computer games]
FF 8- Jav 42 mpg run, 1949 24 hour Spa
Fisk Jav experiences cam wear, crank dog
FF157
(Photo..1931 tourer)- Vic Morrison's
(Photo..camper on Jup chassis)- UK, 1950s
(Away North, Away South)- A framing Jup Wgtn-ChCh in 1970s. Vic M
(My Braddy, My Workhorse)- working lorry, Mort Cruckshank, Hokitika
(Unleaded Petrol & Additives)- AA Fuelstar test details etc. Emms
(Fuels Update)- unleaded, susbst additives, vapour lock. UK
(F.O.M. Call)- LTSA Rules, towing, tyres, compliance engrs
(Advert)- Jav, "She's A Lady"
Safe Jowetting; Steering Failure- arms, loose box, cone adj
A t C- diff breather, Grandfield obit, Spa Jav, 1930s useage UK
FF 9- oil coolers, Duncan exper, cam/rocker float
water in ram tube, dis battery leads
"Dog & Lemon Guide"- review
[Fuelstar, Fair Trading Act-]
FF158 1999
(Photos..Berney 7 saloon, Young 7 coupe)
(Another Jowett Resto Project)- 1930 2 dr saloon, Norm Pegg
(Complete Jowett History)- potted, photos many models, Ray Win
(Petrol We Use in NZ)- additives, Fuelstar responses, Neil Moore
A Tiring Tale of Fatigue 1/3- intro to metal fatigue
A t C- cross ply brands, Thornber cont'd on 1930s
FF 10- 1951 Jav test, Padman & Wilson car
The Way We Were- A framing
On the Smell of Oily Rag- extreme mpg vehicle
[Ah So]- chainblock test card
FF159 1999
(The Making of Joey)- rebuild of a 1931, Vic Morrison
(Willie in the Wilderness) - driving rebuilt 1924 in 1973, Vic M
(Photos)- both above
(Auto Architect)- review book re Gerald Palmer, prod line photos
(Solving Overheating Problems)- trouble chart
Brakes Breaking You- Jav brake quirks, rear backplate dimples
Sid Tries Again- Power Up additive
Aside- standing of obsolete oil quality ratings
Crash- comment on TV prog re crashworthiness
A t C- Thornber and 1930s Jowetting, Jav hot smell mod, 10 brakes
[Hallowed Silence]- Ballykiss Jav
FF160
(Photos..two Bradford trucks)- Vic M's, Ken Proffit's Whakatane
(Best Most Original)- Dick Graham's Jav, incl some mech hist
A Fellow Sceptic- accessory oil additives cf modern oils
Angle of the Dangle- Leaf spring shackles
A t C- Thornber in wartime incl kero, supercharged Jupiter
Clements in Marrakesh rally incl Suzuki rims and mods
Moderns and Drivers- road toll
[Ballykiss]-
FF161
(Jupiter Restoration Project)- Ray Win's Jupiter, incl photos
(Jowett Publicity 1924)- sewer pipe drive with photos
A t C- Thornber, Clements rally contd, CC crankcase breather
UK lead substs, inhibitor recom, inserts, timing odd cams
Related Diatribe- anti old car pressures
FF162
(Photos.. 1929 chummy, 1934 Kestrel, 1938 8, 1937 10)
(Palmer Obituary, 1948 Jav adv)- Nankivell
(Another Jup Not Stuffed Exhibit)- Grudnoff car photos. Stanley
Exhaust Pipe Dreaming- Oxygen sensors
A t C- ohc heads, Thornber postwar prices, tie bolt leaks
valve seat wear factors, FBHVC tests of lead subst
More From Sid- Bi-Tron oil additive
[Apoplexy]- Fuelstar
[New, Sad Experience]- Toyota sale
FF163
More Fatigue 2/3- practical life relative fatigue limit,
influence of shape and finish, peining, rolling
A t C- PA hub seal mod, Jup No 1 in US, 175/75x16, Farr fhc Jup
[Reflections]- Fernyhough collection, Jack Stanley
As You Were- Glycol shortcomings
FF164 2000
(Step Out Alive)- FF 1972 crash with seat belts; Hartley Keswick
(Jowett Parts Meeting)- alternative bearings etc; Moore
(Across Africa 60 Days)- one page summary of 1926 trip
Believe It Or Not- engine temps, pressures, oil films, oilways
A t C- seat recession factors and additives, non BS for LRP
FF 11- vintage mechanicals; Buxton
Economical Reading- Classic car mag model comparison limitations
FF165 2000
(Photos.. Bradfords)- incl David Winder
(Jowett, Early Years)- history, with Xeroxed photos. Garside,UK
(Javelin Crankcase Breather System)- Emms
Interest Ignited- conventional and high energy systems
A t C- head gasket overlap
FF 12- Bill Boddy and Jup, oil hose rejuv
[Correspondence]- with UK re LPG
[Bemused]- F1 cars
The Consumer Soceity- relative prices, cheap wreckers
FF166
(Photos.. NZ Jups)- incl racing
(Jowett in the 30s)- history, with Xeroxed photos. Garside,UK
(Member Profile)- John Holloway
(Adv)- Jup at Le Mans
(More Technical Info)- wide plug gaps on Brad, Pegg
Back to Basics 1/2- steering, susp alignment general, toe
castor error ref FF196
A t C- early UK econ run, very defective Jav eng
FF167
(Photos..pre war
(Observations From Wkshop)- fan keyway, valve seat, guide wear
flywheel rubbing. Vic Morrison
Energy For It- energy reqd bikes cf cars, cycle industry
A t C- bronze petrol filter, Lunn, Jup cranks in US
petrol additives and LRP in UK
Ignition Rekindled- semi and true high energy systems, distr caps
[Two Dollar Shop]- supply source
FF168
(Photos..Farina Jup, Berney's early 1930s 7)-
(Member Profile)- Tony Keyworth, Rotorua Bradford)
(Advert and photo 1936 10)- Jason/Jupiter model)
Terminal Fatigue 3/3- case hardening, crack detection
bolt tensions, dubious components
Another Tale of Long Ago- crack testing
A t C- several JCL reminiscs incl Monte, Isotta engine
FF169
(Larger Jowetts for 1937)- review from "Light Car"
Back to Basics 2/2- camber, bump steer, ride height, toe, diags
A t C- long journeys to Perth rally
More Nostalgia- broken pistons
Stop Press- re docu of tech probs, greasing of w.bs.
FF170 2001
(Photo..woody Bradford)- Berney
(The Tug)- homemade Bradford tractor, Morrison
(Brakes)- restriction reservoir to master cyl, Morrison
(Water Taps)- deceptive operation, Gray
T'Other Way - bump steer using hinged plane
Cool Topics- overheating
A t C- popped synchros, Purvis shunt, Le Mans, Jup at 50 yrs
FF 13- steering box removal, Morrison racing, Bradford oil press
[More]- comment on docu of tech probs contd
FF171
(Adv 1924)- Jowett 7 with ref to clutch
(Photos)- Mawhinney and Lauder Brads, and a 1950s wkg Bradford
(Wkshop Observations)- carb gasket, loose ring gear-Vic
(Unloved)- Allan Dick on Bradfords-Vic
(Jowett Javs)- quirks-Brizell
(Fitting Jav Windscreens)- Connaughton-Australia
Bedtime Stories- Ricardo and bmep
A t C- Penrite oils, cam thrust plunger
A Blast From Past- re Noel Bird
In the Beginning- Joey the Jeep and my interest in cars
A Puzzle- burned piston and corroded shells Davidson Jav
FF172
(Adv)- 1920s 2 str
(Photos)- CD2, CD3, 7 2dr saloon
(Too early, Too Late)- review of Jav as a classic
(Workshop Observs)- top susp end movmt-Vic
In the Thick of It- Multi grade oils and shear, API ratings
A t C, FF14, FF15- `` Jav vs Cortina, Javs in Econ Runs, drag coeffs
FF173
(Adv)- 1920s dickey
(Workshop Observs)- Bradford rear camshaft oil leaks-Vic
Oil Leaks- threads, tie bolts, timing covers
Trekkas and Other Marvels-
Preventative Maintenance- diff bolts
A t C- Bosch part nos, plug alternatives, balance seal
FF 16- oil cooler, veh numbering, contemp Jup tests
FF174
(Adv)- 1920s 2 str
(Photos)- 10, Bartram and Morrison Javs
(Workshop Observs)- worn Brad mains, broken VW piston in CD-Vic
(Triumph 1500 vs Jav)- handling and tyres-Vic
(Obituary, Charlie King)-
Bearing On My Mind- crank bearings and centrifugal forces
A t C- orig Wylie Jav
FF 17 - Davidson Jav, 1st Padman eng, ram tubes
LTSA At It Again- 2nd hand brake shoes
More Oil- monograde and 2 str diesels
[Learning from Brits- creating spares sales]
[Hallucinations- Javs in Auck]
[Buyer Beware- Moprod parts]
FF175
(Adv)- Australian Bradfords, with local ute bodies
(Rumblings and Grumblings)- Jav exh vibration-Dingley
(Workshop Obs)- Jav head gasket installation-Vic
(Taupo or Bust)- 1982 reprint of CD3 descrip, maiden trip-Vic
S.F.C- Specific fuel consumption, aero and Jav
A t C FF18- NZ Javs on hp test bed
LTSA Tries Again- proposed ban on mixed tyres
More Hassle- LTSA and seat belts in oldies
[Dream Shattered- Kim Hill and Javs]
FF176 2002
(Member Profile)- the Berneys
(A Lad and His Jupiter)- his first sports car-Vic
(Taupo or Bust Pt 2)- CDR3 porous liners-Vic
(Workshop Observs)- driveline defects-Vic
(Gearbox Bearing Puller)- engages circlip groove-George, Aus
Thrown a Wobbly- engine balancing, incl flat 2. Pt 1
Exploring Godzone- secondary routes Auck-Wgtn
A t C, FF19, FF20- Jav eng development, Jason test
NZ testbed Jav road hps, Wgtn econ run
Oil Usage- consumption and change periods
FF177 2002
(Photos)- NZ "Dragonfly" special
(Adv)- early 7 2str, "big pull"
(Members)- Garry & Sue Dingley
Sarah Brown, Ian Howell
(On Cyl Heads & Valve Gear)- hard seats, sleeved guides
follower caps, carb spanner, head puller; McKee
(Liner Puller)- N Moore
(Workshop Observ)- petrol pumps; Vic M
Boxing On- Bradford crank "balancing" Pt2
A t C- spec heat of antifreeze, Forsheda gearbox seal
susp reservoir leaks, elec fuel pumps
Rallying Enthusiasm- Wgtn area trips
[Holiday Road Toll- modern cars]
FF178
(Adv)- early 7 4 str, "big pull"
(Members)- Leao Padman
(A Bradford Tale)- extensive 1950s experiences NZ; Pairman
(Wksp Observations)- stuck carb jets, distr bodies; Win
Old Motoring Old Cars- advocating secondary routes
A t C F 21, 22- FF21 prototype Jav, FF22 Padman Jav
[Sorry Javelin- trouble with moderns]
FF179
(Photos)- Colour ,of NZ Farina Jup, R1 replica, Jups etc
(Wkshop Observs)- valve guide wear epidemic, hardtop for CD3; Vic
Tyring Work- diy tyre changing, balancing
A t C- Australian Jav import figs, boot seal rubbers,
hub lock rings, speedboats, cracked rims, 1940 8, Jav dhc
FF180
(Photo)- Vic's tourer
(Snowgood)- snow driving, starter pinion failure; Vic
(Chokes and Starters)- choke control adj, starter direction; Vic
Exploring More Godzone- NI secondary routes
A t C- wheel cracks, Fergusson motors, radials,
NZ Economy Runs, yesteryear valve life
FF181
(Photo)- Farina
(Farina Farewell)- ownership of Farina Jup coupe; Wally Fletcher
(Of This and That)- Jav driveshaft plugs, Bradford eng mounts; Vic
(Advert)- 1920s coupe
Tooth Care- gearbox lubrication, visc table, history car gboxes
[Less Haste, More Speed- pitfalls of hurry]
[Relevant- valve seat wear not inevitable]
FF182 2003
(Photo)- CD van bonnet off
(Adverts)- commodious features 1930s van and car
(Epic Bradford Journey)- across Australia 2002
(Cloud 9 Over Jup)- Allfrey story
(Ping Ting)- broken starter spring, Triumph starter; Vic
Crankshafts Around Again- Types and failure of
A t C- Australian cast cranks
More Reminiscing- Jav ride
FF183
(Advert)- Long 4 spaciousness
(Sparks)- misphased 4 cyl distr cap on 7; Vic
(Flat Out)- restored R1; Vic?
(Thoughts)- reflections on his cars; Vic
Considered Change of Orientation?- polarity reversal etc
The Coil- polarity
A t C, FF23, FF24- Wgtn econ run, BP hp tests incl Padman cars
gearbox leaks, radials, 2nd hand prices
A t C- milling of cyl head water jacket
[Meeting Henry- ride in a T]
[advent Tour in NZ]-
FF184
(Photo)- Howman 8
(Adverts)- structure features 7, cartoon holiday 7
(Members) - Ken Orams, and his Bradford owned since new
(Javelin Floors)- Vic M
Tools, Methods- amateur improvisation
Skinning the Cat- polarity and volt regs
A t C- restored R1, VIG10 carbs
A t C, FF25- "Road & Track" on Jup
FF185
(Advert)- early 1920s long with hood
(Bradford Brakes)- adjustment Vic M
(Maxi vs Javelin)- comparison, Vic M
(Members)- Paul Wallace and Bradford
(Fall and Rise of Bradford)- smashed Cruickshank Bradford
(Richard Pearse)- Neil Moore
Reminiscing Again- motoring in the 60s, 70s
A t C, FF26, FF27- Wylie car, Econ runs incl SI record, carb ice
More Asides- Fordsons
Airplanes Do It- Boeing crank failure 1919
Another Oval Web- giant ship crank
FF186
(Advert)- R4
(Photos)- all CDs, incl CD3
(Member Obit)- Dick Williams
(Bradford CD)- Phill Green etc
(The Dinkham Oil)- advocating 25W/40 after experience. Vic
(Trapped)- projecting screws. Vic
(Indicators and Windscreen)- fitting of. Vic
Assembled Advice- work practises
A t C- Jav in 1952 Monte, '49 car ident
oil recommend, lowering oct, bigger waterways, distr rotat
Swift Swapping- jacking tip
[An Afterthought- caption]
FF187
(Advert)- using tiller steer car
(Tuffey Jowett History)- Jav now Jup owner
(Mobile Phones, Flammable Gases)- incl static
(CD Feedback & More CD Talk)- NZ esp. Vic
(Workshop Observs)- Bradford brake expanders
changing Jav filter cleanly, gbox mtg. Vic
A Worrying Time- starter pinion problems
Superman- fitting screens
[Thinks- Model Engr link, Harland and Wolff]
A t C- Bradford hints, prewar performances
gbox leaks, Fergusons
[Grandfather's Clock- Minx at funeral]
FF188 2004
(1935 Jowett)- recent West Aust review of 4 str tourer
(Jav Steer Wheels)- rubber under and lace up cover for rejuv. Vic
Another Handle on Handling- Jav over/understeer factors
A t C- burned valves older cars, seat concentricity
Swedish Monte Jav, gear change col fail, Farina Jup ex france
Legal Speed Car Drivers Endangered- 90 kph legal for trucks
FF189
(photo)- Jowett 8 dashboard
(Spring Bushes, Oil Leaks)- Nolathane, split cooler hose. Vic
Rambling- routes Auck to Taupo
A t C- makers of valve seat inserts, d.d. SUs etc, s/a substs
asstd hints incl setting oil relief, pressure test cooling
FF190
(That Phoo Phoo Valve)- crankcase breather. Vic
(Ken Cuff Writes)- Bradford jeep 1960ish
Manifold Tunes- tuned inlet and exhaust systems
A t C- kingpin offset, cast cranks, cam follower angles
valve train probs inc cam journal wear
FF191
(Photo)- Javelin assy line, crankcases, Bradford eng on test
(Photos)- Vic's chug, SI lineup Palmer designed cars etc
(Advert)- new Jav and Bradford
(Stopping Your Javelin)- general advice; Vic
A Moral- timing of lawn mower eng
Buyer Beware- dud Warehouse filters
A t C- Tulip Rally reflects, subst fwbs, ref Laycock o/ds
Reprints- Jav cf SM1500, Aust 1954 used prices
FF192
(New Make Reviews, Jav, Brad)- 1948 reprint Aust mag
(Is Cooling System Adequate)- enlarged way in timing cover
(Major Surgery to CD3)- lowering chassis; Vic
(Workshop Observs)- torsion bar adj; Vic
(CA CB Valve Timing)- inc prewar, valve and ign. Moore
(Those Extra Spares)- futility of over stocking
Soggy Stoppers- tilted shoes, snail cams
Woe Continued- dud Warehouse filters
A t C- fwbs conv, Spa Jav, 60s prices, twin balancing
old twin eng, experience without lead, overdrives
FF 193
(BSF Hardware)- Allfrey
(Advert)- 7hp quality
(Photo)- Flying Fox chassis and frame
(Brakes, Electrical Tip)- shoe configuration, open ammeter; Vic
(Ray Win)-
Power to Burn- power to weight ratios
A Price of Progress- distractions in modern cars
As You Were- failed oil filters
Reflecting Again- roads in 1920s-50s
Good Support- lifting vehicles
Take a Look As It Passes- Javelin in 1950
A t C- diff breather, 1st Jupiter now, rejuv instr dials
FF 194 2005
(Photo)- NZ R1 replica
(Back from Brink)- starting laid up Ten, firing order. Vic
Ring a Ding Ding- crankshaft ringing for crack detection
Billy T Overdrive- coasting
A t C- jacking practice, BSF, orig Jav tech develop article
Silicon fluid, carb balancers, EP for gearboxes
FF 195
(Letter)- rpm and longevity. B.McKechnie
(Advert)- vintage engine details, large counterweights
(L=100 Car)- NZer ex JCL, incl photo of 1910
(Mixed Fluids)- water leaks in Javs. Vic
A Grasp of Handling- over/understeer, VW, anti roll bars, pitch
Capable Morris- ohv Oxford cf Jav
In Your Face- steering wheels over the years
Improving With Age- Jav economy
A t C- proposed new crankcases
FF 196
(Photo)- Sid Bradford's 7 saloon
(Twenty Years Braddy)- Mort Cruickshank
(Jowetts Under Hammer)- Waihi auction
(Miscellaneous)- Nolathane bushes, photos 10 bare, CD3. Vic
(Javelin Oil Pressure)- factors, incl crankcase breaks. Vic
Castor Disaster- castor influence, correction of previous FF166
Gear Oil Again- GL4 and bronze
Stopping to Reflect- legal reqmts, truck and trailer limitations
A t C- Jup side windows, 10hp van
FF197
(Photos)- Sid Bradford's 7, 10 grille
(Life in Fast Lane)- late JCL history with photos from recent
Yorkshire magazine; Phill Green
(Four Wheels Good, Two Better)- Koch-Osborne's Jowetts
1st wheel steered, greenhouse, 1920 special
(Octogenerian's Museum)- Ray Win
(Vic's Tug in NZ)- photo, also CD3
(It Won't Go)- stale petrol in Ten-Vic
Castor Pull- explan
Old Hat- wearing of
Sanity Prevails- emmision testing backdown
A t C- Bradford xcase depression, Jav water flow equalisation
VIG carbs, ref to 2nd Motor Sport reprint & Grandfield
McAuley's crash videos, ref to ex NZ article on Buxton car
FF198
(Photos)- Tulip Jav, restd Mead, int Vic's 10, ex NZ Jav Holland
(Prolong life of Battery)- additives, storage
(Tick to a Knock)- worn Bradford camshaft. Vic
(Fixing That Horn)- Jav horns. Tim Kelly
Decision Making Old Style- oldies driving tests
Then and now- road improvements over the years
Emitting Again- CO2 and tests
Little Toot- horn faults
A t C- low temp thermostst, diff bearing nos, hub pullers
Jenks and Mille Miglia Pt 1
FF199
(Photos)- Vic's Ten
(Restoration Thoughts)- successful restoration philosophy. Vic
(Why Did Jowett Fail?)- Davidson
(A Short guided Tour on Jowett's History)- Davidson
A Grasp of Handling 2- weight tsfer, roll, roll centres
roll couple, random steering front
A t C- subst elec Jap distribs, Jowett 10 perform cf others
gearbox front sealing, Jowett web site
Galloping On- boy racers and car performance
