Page 1 of 1
oil reservoir on front suspension
Posted: Mon Aug 03, 2015 4:27 pm
by M S G Benning
what do members put in these reservoirs oil seem to leak out
Re: oil reservoir on front suspension
Posted: Mon Aug 03, 2015 7:15 pm
by Forumadmin
Well of course the answer is to renew the seals....
See this post in the Early Javelin Rebuild project
Posted: Wed Apr 27, 2016 1:19 pm
by rickjowett
I have the same problem, oil leaks from the reservoirs. Where are the seals whick leak and where can I secure new ones?
Posted: Wed Apr 27, 2016 11:07 pm
by Keith Clements
http://jowett.net/forum/viewtopic.php?f ... ion#p17803
JCS although I think the ones they supply are too small a diameter. They are O rings. But see my set up in the JT post.
Posted: Thu Apr 28, 2016 1:06 pm
by rickjowett
Hi Keith,
Thank you for your reply.
What is JCS?
I am still not clear on what part in the link you reference is leaking? I am not familiar with this part of my Jupiter and from the pictures in the link I am still trying to figure out what part is the culprit? Can you clarify for me please?
Posted: Thu Apr 28, 2016 11:05 pm
by Keith Clements
Jowett Car Spares. The spares function of the Jowett Car Club, which you should join.
Please look at the early parts book. TOPIC Page 20 and TOPIC Page 21
Item 773 Part 50496
Leaking from the reservoir is very common and many do not bother fixing it, preferring to keep filling up. Wear on the shaft and other places may be causing the leak as well.
Posted: Fri Apr 29, 2016 1:09 pm
by rickjowett
Keith,
Thank you again for your time and help.
Rick
Posted: Thu Jul 07, 2016 9:33 pm
by Edmund Nankivell
I use a thick oil, SAE80 or thicker, mixed with a little grease,
Posted: Tue Aug 09, 2016 8:32 pm
by rickjowett
Edmund,
Great idea, will try this.
Rick
Posted: Thu Aug 11, 2016 11:24 am
by BobCulver
It is important that leaking oil does not soak the torsion bar bushes as replacement is a mission. I dunno about jupiters but Javelin rebound buffers also dissolve and many are missing and unknown to owners. Can overstress steering linkages on rebound.
Posted: Wed Oct 12, 2016 6:29 pm
by rickjowett
Just tried this last month, works great! Thank you.
