Jacks
ajg1722
- Your interest in the forum: Current restoration projects: Bradford CC Truck, 1939 Tatra 57b.
Also have 1953 Ariel Square Four, 1958 Velocette Venom, 195? Panther M100, 1963 Standard 7cwt Van, 1963 Standard 7cwt Pickup, 1976 MZ TS250/1, 1984 MZ ETZ250, 2001 Toyota Hilux, plus a couple of CZ 175 bikes, all variously running or awaiting restoration. - Given Name: Andrew
Jacks
Trolling round the internet looking for info to refurb an old trolley jack, I stumbled upon this web-site: http://mgaroadster.co.uk/vehicle_jack_index.htm
It is a mine of information. They have listed the jack(s) for javelin and Jupiter, but not Bradford.
Now does anyone know what jack was actually supplied with the vehicle? Or any other tools for that matter?
Cheers,
Andrew
Cheers,
Andrew
Andrew Henshall
Re: Jacks
I've been corresponding with the creator (Steve Gyles) of the excellent jack website for a couple of years and provided him with the info on the Jupiter & Javelin jacks. Not being a Bradford owner, I was not able to help Steve with info on the Bradford jack - hopefully someone out there has this info.
Andrew
Andrew
Andrew Henshall
Member: JCC, JOAC & JCCA
Re: Jacks
the Bradford came with a small mechanical ''bottle'' jack. I don't know what make it was but it wasn't specific to the Bradford as it was used under the axle not a speific jacking point
Re: Jacks
Re: Jacks
definitely not Bradford. The Bradford jack was a common screw type bottle jack with cast iron body as used on many makes of vehicle. Other tools included, tyre pump (hand operated) wheelbrace , grease gun, oil can, axle filling nozzle, tyre leaver, adjustable spanner, spanners 3/16 x1/4, 5/16 x 3/8,5/166 x7/16. screwdriver ,pliers, ignition screwdriver, box spanner 5/16 x3/8, tommy bar, spanner for gearbox filler, spark plug spanner.
George
George
Andrew Henshall
Re: Jacks
You are 100% spot on David, according to the internet, that's a '72-'78 Toyota Pickup jack.
Andrew
Andrew
Andrew Henshall
Re: Jacks
currently on ebay several jacks similar to Bradford and certainly of correct period although not sure if exactly same as Jowett issue
'old car jack lake and Elliot midas £8.50'
'Dunlop 15cwt vintage car jack £12'
'vintage shelley 8 inch car jack'
I found these under 'old car jacks'
ajg1722
Re: Jacks
Yes, there are lots of jacks out there, more than you can shake a stick at. But the real question is which one or ones were actually supplied with the vehicle. To produce on the scale that Jowetts did, they must have had a regular contract for supply.
And as time marches on this information will be harder and harder to track down.
I might also add that this question could be directed at the rest of the tool-kit
- Andrew
- Andrew
Re: Jacks
Does anyone have pictures of the 'official' tools as mentioned by George, particularly those of the vintage (i.e. pre-1930) period?
I suspect that there may have been a variety of items depending on price /availabilty.
In particular, I would like to see a typical wheel brace. I guess a bit similar to the Javelin items but possibly more primitive?
Andrew Eales
Re: Jacks
This is the Jack and wheel spanner, plus tool kit that came with my Bradford. No idea if its the original article or not !
Andrew
Andrew
Andrew Eales
Re: Jacks
And another
Andrew Eales
Re: Jacks
And one more
Re: Jacks
can't be certain but lit looks very like the original jack and toolkit and is certainly of the right period
