replacing lower swivell pin bushes and spring arm pin
CyrilWhite
Post by CyrilWhite »
I have just ordered the parts to replace worn bushes/pin. Any tips on replacement,for e.g can it be done without removing the king pin. Are the bushes easy to remove, ? ..will it need a special tool .?Also reaming of bushes procedure ,tools needed etc.
.Any bits of advice will be most helpful.
The suspension is the early type - not rubber bushed.
