fitting replacement temp gauge ! plus rad.
bernard
Post by bernard »
Removal of radiator incurred ,with care !! pipe from gauge to the radiator breaking. ok not the end of the world , i have replacement gauge to fit the replacement radiator. ? how does one pass the pipe with the large securing nut that fits the radiator through the scuttle . ?
BERNARD GILLETT been a member of the jowett car club for over 25 years . run a 1952 javelin de lux.
Re: fitting replacement temp gauge ! plus rad.
It should just fit through the hole but if you have more wires or pipes you may have to temporarily remove them. You may also need to dislodge the grommet.
