Today we took part in the Cottenham Yesteryear Road Run, along with around 300 other cars, motorcycles, commercials and tractors. A round trip of about 35 miles including the road run itself. The weather was a bit bracing and my worries about overheating in traffic have proved to be unfounded. With the newly rebuilt radiator, it's running a bit cool if anything.
All still seems good, but there's a healthy oil leak from the pump when the engine's running, with about a litre lost today, so that needs looking at as a priority. It was the first time it's been out on long stretches of open road and while the engine runs well, it clearly lacks power. With 4 people aboard it will cruise at around 30mph at 1/4 throttle, 30mph at 1/2 throttle and 30mph at full throttle! Once out of the villages, it was very noticeable the Austin Sevens etc were disappearing from view rather rapidly. In fairness, 30 is about as fast as you'd want to go with the steering the way it is at the moment with around 4 inches of play. Coming back with just 2 of us, on downhill stretches I felt the terror they must have experienced up on the bank at Brooklands in the glory days!
From looking at it with a strobe, I know the timing is a bit "variable" and it is booked in for a proper distributor rebuild in June. It still splutters a bit pulling away and has to be warmed up a bit before leaving the drive, but everything I read (including the Jowett Club Pre-war technical notes) says a bigger compensator jet is needed to correct these symptoms. Lack of top speed suggests a larger main jet, so I will go up a size on both. I did read in a couple of places (possibly including the FBHV advice in Jowetteer) that the ethanol in the new petrols can cause lean running and may need larger jets in some engines, but I don't know if anyone else has experienced this?
Could be my nice free flowing exhaust has added to the problem, but it does sound good
At least I am starting out with a completely rebuilt carb with a set of standard size jets this time.
