Early Javelin Restoration
Re: Early Javelin Restoration
The previous repair carries a captive nut for the fastening of the ply sheet floor
I had given the front outrigger a quick lookover and with the exception of a small area on the end of it - passed it for service - however - has I commenced cutting out the small section it quickly became clear that it was playing host to hidden can of rust worms
I thought that I may be able to fabricate a repair section but ended up removing all of it
One dead outrigger
Keith shot blasted the area above the outrigger now that it could be accessed - I then sprayed it with a zinc rich primer - prior to applying seam sealer to the seams above the outrigger
Although seam sealer was never applied at the factory we are not going to let that fact prevent the use of it now - the remaining seams shall all be sealed once the repairs are complete and the shell is back to bare metal and primed (always apply seam sealer to a primed surface - not a bare metal one)
Outigger trial fitted (Jowett Car Spares - supplied)
Last section on the A post was at the top where the upper side mounting for the front wing is located
the bracket was removed and the failed area cut out - new metal let in and the bracket reattached
Last edited by Chris Spencer on Wed Feb 06, 2013 11:39 pm, edited 1 time in total.
Moving on down the nearside of the car now - the centre outrigger which also forms the jacking point for the car was next on the list
At some stage it had been over plated and the rust had just worked from the inside out - plan is to replace it with new one supplied by Jowett Car Spares
The exhaust pipe travels through the oval section in the outrigger
The outrigger supports both the sill at the centre point and also the B post from which both the front & rear doors are hung
So the doors were removed to take the weight off the B post before the outrigger was removed
Then a section of 50 x 25 mmm box section was welded in between both of the B posts and attached to the chassis rails again with box section - this ensures that the posts remain rigid and in the correct location whilst the work is undertaken
The outrigger was removed to reveal yet more rusted out metal under the B post
So only one course of action then - first some heat was added to burn the lead out that had been let in over the rebated welds between the post and the sill
Then the section was cut back to sound metal
A new section was made up and tacked in
A good check and measure was made prior to welding the B post back to the new metal / sill
The new outrigger was trial fitted
The factory jack was also checked to ensure that it did not foul the new sill section
Chris has not reported on two tricks he used.
He pinched some of 'my' welding wire to make a pattern of the shape of the sill. This captures the correct angles allowing him to easily check when bending to shape.
He also used a sheet of thick copper under the seam to be welded. This helps prevent blow through of the weld.
p.p.
Given Name: peter
Post by p.p. »
your all of thousand tricks :!: :!: :idea: :idea: :idea:
THE LANGLEY GANG 8) 8)
peter - snow bound.....to cold ....
Couple of tricks I use to make the process easy - they are just simple timesavers - for template profiles I use a short length of welding wire and just bend it shape with a pair of pliers
To prevent burn through when welding between repairs / panels - especially if you have a small gap - use a peice of copper plate on the underside of the weld - this in turn prevents the burn through and the weld will not attach to the copper plate - it also results a flush weld on the underside and minimum dressing of the join
