with those interested in the cars from Bradford, England. If you want to post on this forum you need to register. The site uses cookies and uses security certificates when you are logged in.
Attached is a pic of what I assume is a dash cluster from a Jowett. This is based on the fact that the Oil gauge says JOWETT. I am hoping that you can help me ID the correct models and years that it would fit.
Mark Masa http://www.linkcycles.com
<mark@linkcycles.com>
Keith has been a master of brevity with his answer, however if I may, I will try to flesh it out a little for you.
The Jowett Bradford started production in 1946 and the last few were sold in 1953. It was a development (but not a quantum leap) from the Jowett pre war design. It was a commercial vehicle capable of a 10Cwt payload. It was initially available as a van then a utility able to seat 6 people and even a small Lorry (pickup). Around 40,000 were made but only a few hundred survive. Sadly however the value of your dash panel and even a fully restored Bradford is not great. A good one may fetch £3500 and an excellent one as much as £6000. If you would like to know a little more I can point you in the direction of those far more knowlegable than I.
