I have the above distributor on my Long 4 7hp and noticed the other day that the spring on the top of the rotor cap was not really connecting with the center bush of the distributor cap. It appeared that over the last 90 years it had worn down. This distributor cap does not have a sprung loaded graphite slug that can easily be replaced, like more recent distributors. On investigation it appeared to have a white metal slug (cylinder) that is soldered to a brass mount that is in turn attached to the center of the cap. See image attached.
To rebuild this part of the cap I was able to mount the cap on my myford lathe (Using 3 jaw chuck on inside of cap, very carefully) Then using a 3.85mm slot drill in the tail stock, machine out the original rivet head, this allowed me to push out the rest of the brass mount.
After measuring the original. I turned up a replacement mount in brass. tThe inital problem was how to create a long exposed slug of white metal that was securly attached to the brass holder. The answer was to incorporate an extra long cup on the holder with a 7mm internal diameter then fill that cup with white metal (using bakers fluid flux) When solid, I was then able to turn away the excess length of brass cup leaving the exposed white metal protuding from the brass holder, where it was securely soldered in place. Finally I used a 9ba screw and brass washer to secure the new holder in the cap.
Lucas distributor cap repair 1929 7Hp DS2 1495/ 529
Dhbangham
- Your interest in the forum: Jowett long four owner. Jowett club member. (Former Armstrong Siddeley 20hp 1932 owner and ASOC member and former Lancia Belna 1935 saloon) Lanica owners club member. Interested in driving my cars especially in europe and making and repairing parts for the cars. I consider myself an oily rag owner.
- Given Name: Daniel
Dhbangham
Re: Lucas distributor cap repair 1929 7Hp DS2 1495/ 529
Update of the cap repair: Although the car runs with the repair I made to the cap using white metal as the center contact material, it has a tendency to mis fire and run rough. Now I have rebuilt the engine and check the carb, I though I would re-do the repair and replace the center contact material with Graphite, which the traditional material. The car now runs beautifully. Picture shows the inside of cap with the center contact removed, on the right is the new terminal, with the carbon brush just visible at the top and the screw mechanism that hold the contact in place.
This sort of repair is I think essential if we are to keep cars as original as possible, since I have been unable to find another example of this model of distributor or its cap.
