Electric cooling fan
bobharvey
Your interest in the forum: Owns a 1952 Javelin DeLuxe
Given Name: Bob
Post by bobharvey »
I’m sure many owners have added or substituted an electric cooling fan. Is there a particular make or size that’s known to work well? And has anyone removed the engine driven fan blades, which would seem logical, decreasing noise, reducing energy waste, and speeding warm up.
Re: Electric cooling fan
Bob, A search using the word 'cooling' brought up many results
viewtopic.php?p=41777#p41777
Shows the 1970 version which has subsequently been replaced by a fan behind the rad controlled by the same thermostat. Other thermostats are available including ones with a bulb that easily fit in the pipe coming out of the water pump.
Various makes of fan are available, the diameter and width are the important specifications to look at. You need one to fit behind the rad. Most will rotate either way by reversing polarity of the connections. Make sure it is sucking not pushing air.
viewtopic.php?p=42028#p42028
Unlike the Jup, there is not a lot of space between rad and bulkhead. On Amy's Jav the fan just slots in and does not require fixing.
I have run both Javelin and Jupiter without a mechanical fan but have retained the ability to replace it.
