My specific question relates to the 'tag' end of the wire from the condenser and the 'tag' end of the wire which goes to the body of the distributor. Both fit onto the post of the contact baseplate.
I know that there is a fibre washer at the bottom of the post, then the 'spring' end of the contact breaker, then the 'tag' ends, a plastic insert separating the ends from the post itself plus a metal washer and then the nut. But should there be a washer between the two tags or should they make direct contact? If there should be a washer should it be a fibre washer?
Please note there was no washer between the tag ends when I removed the old set AND I last ran the car twelve months ago in that condition- and, yes, it did run!
Has anyone got an exploded diagram of the contact breakers, please?
